Civil Engineering Association Software Software Product Autodesk Products Autodesk SketchBook Designer 2012 (x32/x64)
 niki102
User ID: 8143
Threads: 82
Likes: 2,495 in 189 posts
Given Likes: 845
03-24-2011, 07:34 PM
Autodesk SketchBook Designer 2012 (WIN32/64)
[Image: 60313705748005774664.jpg]
SketchBook Designer - hybrid raster and vector drawing program, formerly known as Alias ​​Sketch. In contrast, SketchBook Pro, SketchBook Designer has great potential, mainly associated with the vector drawing.
SketchBook Designer provides incredible flexibility and accuracy in digital images.
Designed specifically for graphics tablets and Tablet PCs, SketchBook Designer provides all the tools necessary for the transition from pen and paper to a digital environment.
SketchBook Designer supports AutoCAD 2010, AutoCAD 2011 and AutoCAD 2012, but does not support vertical solutions AutoCAD (eg, AutoCAD Mechanical, AutoCAD Architecture, etc.)
Key features
- Lots of natural brushes for painting
- A set of professional and quality tools
- Support for working with layers
- Adjust the color, contrast, transparency, etc.
- Creation of custom brushes to paint
- Ability to make notes and add comments
- Built-in ability to send electronic messages
- Interaction with other means of graphic design
- Support the format of PSD (compatibility with Adobe Photoshop)
- Easy to understand and use interface
System requirements
For 32-bit version of SketchBook Designer 2012
- Operating system Microsoft ® Windows ® 7 Enterprise, Ultimate, Professional or Home Premium; Microsoft ® Windows Vista ® Enterprise, Business, Ultimate or Home Premium (SP1 or later) or Microsoft ® Windows ® XP Professional or Home edition ( SP2 or later)
- For Windows Vista and Windows 7: Dual-Core Intel ® Pentium ® 4 or AMD Athlon ® with 3 GHz or higher, supports SSE2. For Windows XP: dual-core Intel Pentium 4 or AMD Athlon processor with a clock frequency of 1,6 GHz or higher, supports SSE2
- 2 GB of RAM
- 1 GB of hard disk space for installation
- Support for screen resolution of 1280 x 1024 mode «true color»
- Browser Microsoft ® Internet Explorer ® 7.0 or later
For 64-bit version of SketchBook Designer 2012
- Operating system Microsoft Windows 7 Enterprise, Ultimate, Professional or Home Premium; Microsoft Windows Vista Enterprise, Business or Ultimate (SP1 or later) or Microsoft Windows XP Professional (Service Pack SP2)
- AMD Athlon 64 processor, AMD Opteron ®, Intel ® Xeon ® processor supporting Intel EM64T or Intel Pentium 4 processor supporting Intel EM64T (all - with support for SSE2)
- 2 GB of RAM.
- 1,5 GB of hard disk space for installation
- Support for screen resolution 1024 x 768 mode and «true color»
- Browser Internet Explorer 7.0 or later
Installation:
Product Key
741D1
To install from the virtual disk is highly recommended to use the program Alcohol 120% or Alcohol 52% at least version 2.0.1.2033 (from myself: I used Daemon Tools)
Disable Internet
To perform activated using the keygen from the x-force_2012_x32
Run the program - see the window of licensing:
1) Click "Activate", the next window, put the checkbox and click "Continue"
2) Regardless of which window will be next, close it and run the activation again. We turn again to the initial activation window
3) Choose "I have an activation code from Autodesk"
4) Run keygen in it and click on Mem Patch (required!!)
5) keygen (domain «Request») copy the request code (Request code) from the window of activation of Autodesk;
- Click Generate. In the keygen-a (region «Activation») we obtain the activation code;
- The resulting code is inserted into the activation window Autodesk.
6) Pay attention to the fact that the code will be shorter than 7 characters - this is normal, "so it should be!
Click "Next" and ready ...
Language: English, Multi
Platform: Windows All
Medicine: present
Developer: Autodesk Inc
[Image: 65821816605710154918.jpg]
[Image: 62427093763443570772.jpg]
[Image: 91753420857671229600.jpg]
[Image: 10211131436406535187.jpg]
Downloaded and installed on windows 7 x32 via following bitshare link(x32 only)( x32 only )
[-] The following 6 users Like niki102's post:6 users Like niki102's post
  • blaze, oanm2000, giga, zrilek, Finna, DamaD
  Autodesk Products 2012 x-force keygen for x32 systems BennyP 7 18,720 03-07-2025, 10:37 AM
  Sketchbook for Enterprise 2019 rami1976 0 4,100 04-16-2018, 08:23 PM
  Autodesk SketchBook Pro 2016 PC x64bit rami1976 0 4,922 04-24-2016, 02:26 PM
  Autodesk SketchBook Pro 7.2.1 Multilingual (x86/x64) er.shyams 0 5,023 08-29-2015, 02:39 PM
Last Post: er.shyams
  Autodesk AutoCAD Plant3D 2012 (x86/x64) BennyP 6 11,609 01-17-2013, 05:47 PM
  Autodesk AutoCAD LT 2012 x32 x64 ISO BennyP 12 20,591 12-17-2012, 03:32 PM
  Autodesk SketchBook Designer 2013 Mohammad6299 0 4,326 09-16-2012, 05:06 PM
Last Post: Mohammad6299
