Civil Engineering Association Software Software Product Non Engineering Software AnyReader 3.6 Build 834
 smk1981
User ID: 130
Threads: 3
Likes: 47 in 3 posts
Given Likes: 41
03-12-2011, 02:58 PM
Scratched, unreliable and damaged media reading! AnyReader is a data copy software for non-readable media: CD, DVD, LAN-Drives, flash memory, ZIP disks, floppy disks, etc. AnyReader effectively copies and saves corrupt data from any type of disks or erroneous connection where the standard copying methods fail. The program supports resumed downloads from the remote PC if the connection was broken while copying (especially useful for unreliable Wi-Fi networks).
AnyReader is great for copying files from scratched CD/DVD/Blu-ray or defective floppy/hard disks. Normally, when your computer is unable to copy files from a damaged disk it will abort and delete the part of the file it has copied. AnyReader will continue copying right to the end; any data that hasn't been recovered after several retries is replaced with blanks. This will allow you to truly copy every byte of information that can be read at all.
[Image: 64717722480325265401.jpg]
[Image: homepage.png]
[-] The following 10 users Like smk1981's post:10 users Like smk1981's post
  â€¢ oanm2000, bhawk0, Clouseau, YaqubMughal, simanta, hcardenas, 3fan, niki102, chigozie, dquan373
 Learner
User ID: 4207
Threads: 38
Likes: 889 in 112 posts
Given Likes: 126
03-13-2011, 11:09 PM
Use Notepad to open CORE.NFO in Keygen folder to view iNSTALL/REGiSTER NOTES: Use the keymaker to register the application as follows:-
1) Install Program
2) Run program
3) Register by using Keygen to Generate, Copy Serial & Patch
[Image: 42910685785630445104.jpg]
[-] The following 4 users Like Learner's post:4 users Like Learner's post
  â€¢ 3fan, niki102, chigozie, dquan373
 jupe01
User ID: 6535
Threads: 4
Likes: 116 in 31 posts
Given Likes: 68
07-16-2011, 05:21 AM
Please Up load again, the link filesonic is dead.
Thanks before for you, uploader.
peace,
Jupe
[-] The following 2 users Like jupe01's post:2 users Like jupe01's post
  â€¢ ranger, kvtasp
