Civil Engineering Association Software Software Product Bentley Products Bentley RAM Advanse 9.5
 sonidero
User ID: 136
Threads: 10
Likes: 451 in 52 posts
Given Likes: 101
07-22-2009, 09:48 PM
Bentley RAM Advanse Release 9.5.0 (2008)
[Image: original.aspx]
Info:
Languajes: English and Spanish
Year: 2008
Format: RAR (3 parts)
Principle of user interaction:
The philosophy of commands (actions) of the program is "to select and implement", ie, to perform any operation, you must first select the elements (nodes, members or plates) and then execute the respective command. This allows you to run commands that affect only the selected members, facilitating the creation of models, particularize reports, etc.
All the tools provided by the program to facilitate the entry and generation of data as well as viewing and printing of results are guided by this philosophy.
Design in RAM Advanse
RAM Advansa Another philosophy that has taken to either the design of steel structures, reinforced concrete or wood, is the "trial and error." The engineer defines the properties (ie sections and materials), and the program checks the members get a list of efforts that the condition of each item. After each cycle of testing, the user is free to change or confirm the properties with or without the application of many tools developed for this purpose. The most important benefit of this procedure is that the user has complete control of designing the structure and the certainty that their needs are being met.
New Features:
1. Panear new way to view and rotate the wheel while pressing the mouse right click according to general applications of drawing.
2. New module design trusses: This new module allows you to analyze and design of wood or metal trusses in minutes. This module optimizes the sizes of the members to maintain the outside dimensions of the trusses and includes a report design of critical members.
3. New and improved shoe design module: The module can now be used as a standalone program or integrated with RAM Advansa. In addition to allowing the design of insulated pads, brake shoes also can design combined with the standard ACI 318-05.
4. New module design concrete walls: This module replaces the previous module walls increased cutting capacity and a new interface. The module can now consider out-of-plane loads and has an option to design wall bending, cutting wall or a combination of both.
5. AISC 360-05 design standard for structural steel (ASD and LRFD methods). We have developed a new component to the design that includes stiffeners armed sections of cut and other improvements.
6. Design standard AF & PA National Design Specification (NDS) for wood from the 2005 edition, which incorporates not only the method but also the ASD LRFD method. The provisions also include the variation of resistance according to the size of the species section for Southern Pine.
7. Design standard AISI North American Specification for the design of cold bending steel in 2001 which includes the 2004 supplement. Include ASD and LRFD methods (LSD method to be available in Canada in April 2008), in addition to the crushing of the soul and wing option subject to floor or ceiling.
8. New memory management: The ability to analyze large models is back. With the implementation of the new scanning engine (FE RAM ™) version 7.0, some very large models gave a memory error. This problem has been solved with a sophisticated memory management to analyze large models and far more quickly.
9. Improvements in the form of walls basculates: After the introduction of the first version of this module, many users around the world has provided us feedback that has enabled us to improve the design of high fashion. Ew this is definitely the best version available in the industry
10. New option to select only those combinations / states you wish to discuss.
11. Plaque load temperature.
12. A new set of graphics that are easier and more legible (supports, joints, loads, reactions, effort, etc.). In addition the new 3D graphics are now a more realistic appearance.
13. This version includes the ability to disable the shear strains. This option is useful when models are textbook examples of verification.
14. Improved analysis and design of steel sections I. The analysis now includes the exact finite element stiffness variable-section instead of the old approach that divided the membership into 6 segments (that option is also available). The design includes the verification of the AISC Manual 13th Edition.
RAM Advanse v9.5 Now Available (Updated)
Updated 8/6/2008 - RAM Advanse v9.5.1 is now available for immediate download from the Bentley SELECT Server. Thank you for your patience between the time this was first announced and now.
As you can see, there is no rest for the Bentley Structural Team. We're also tentaviley releasing RAM Advanse v9.5 in the next couple of weeks. There are a lot of new features and updates in this release. Masonry gets a lot of attention here, with code updates, hybrid masonry design, and cracked section properties. RAM Advanse has plenty of great features and design modules for any material and almost every structural engineering project, so be sure and download this update.
* Minor release just for IMI project
* Hybrid Masonry Design
o Project developed for the International Masonry Institute
o Interface implementation between members and shells
o Forces export to the Masonry Design module
o ACI 530-05
o Joint reinforcement
* Compression-only elements
* ACI 530-05 in Retaining Wall module
* Cracked section properties in Masonry Wall module
* 10 story limitation removed from the Masonry Wall module based on recently published references and IMI advice
* New analysis/design results window
A full list of features and enhancments will be available in the product release notes.
Important Note:
This version of Ram Advansa includes important corrections which even disable the version 9.0.0 of this program, to generate errors that should not exist when using the same model made in versions prior to 9.
The Crack comes in the main folder and is the same as that used for RAM Conecction 5.5 :D
[-] The following 39 users Like sonidero's post:39 users Like sonidero's post
  • jjmtz, jjmtz, haze, haze, KAMM, KAMM, gratiland, gratiland, osin, osin, andersen3, andersen3, rigoleonv, rigoleonv, zrilek, zrilek, panchotevi, panchotevi, Parana34, Parana34, falconado, Octavio, cadtfoi, ferchuz1984, vitacote, Milkshake, tarado, narendra, ReinaldoR, otipca, faxel, joker™, blaze, Ivan_1980, malc, Visitante, nickycruz, ykhackhack, bridgeengineer
 benny
User ID: 748
Threads: 49
Likes: 1,481 in 127 posts
Given Likes: 84
07-26-2009, 06:51 AM (This post was last modified: 07-26-2009, 07:40 AM by benny.)
(07-23-2009, 04:31 PM)sonidero Wrote: In fact the crack is in the folder with the name of RamCon. The two DLLs are copied to the folder c: \ Windows \ System 32.
The procedure is the same as if it were RAM or Staad Pro Connection
Cheers in advance. :idea:
Another crack for RAM Advanse v9.5
This crack will not display the message that goes "You have 1,000 days remaining on your trial license". You may or may not use the two .DLL files in the folder with the name of RamCon.
NOTE:
This crack will be in conflict with RAM Connection v5.5. Use this crack if you will not install the RAM Connection v5.5.
[-] The following 4 users Like benny's post:4 users Like benny's post
  • panchotevi, panchotevi, dalberto, dalberto
 benny
User ID: 748
Threads: 49
Given Likes: 84
07-27-2009, 06:40 AM (This post was last modified: 02-23-2010, 09:33 AM by BennyP.)
Fixed crack for both RAM Advanse v9.5 and RAM Connection 5.5
This crack will not display the message that goes "You have 1,000 days remaining on your trial license". I have added one patched file HWLockDLL.dll in the folder with the name RamCon.
Fifteen has downloaded the medicine applicable to RAM Advanse only, thank you for downloading. By downloading this fixed crack you can install both RAM Advanse and RAM connection.
[-] The following 29 users Like benny's post:29 users Like benny's post
  • aslam, aslam, imran, imran, andersen3, andersen3, KHIEMHAO, KHIEMHAO, pingfan2, pingfan2, mohcivil, mohcivil, zrilek, zrilek, timosi™, timosi™, oanm2000, oanm2000, panchotevi, panchotevi, tomdavar, tomdavar, Floms, Floms, dalberto, dalberto, levanduy, kaungthant, zejuan
 sonidero
User ID: 136
Threads: 10
Given Likes: 101
02-23-2010, 05:40 PM
chek the crack updates include in this subtopic of bentley's products.
[-] The following 1 user Likes sonidero's post:1 user Likes sonidero's post
  • nickycruz
 Civilillo
User ID: 17507
Likes: 5 in 1 posts
Given Likes: 0
03-31-2010, 01:38 AM (This post was last modified: 03-31-2010, 01:51 AM by kowheng.)
(02-23-2010, 08:47 AM)sia1 Wrote: crack link down plz upload again
Here is the crack i use it works for me but if you have windows vista you must follow the next steps:
-Paste the crack at system32 and in syswow64
If it doesn´t work let me know:rolleyes:
CRACK
Procedent page:
It is the same crack for 9.5 and 9.0 ;)
[-] The following 5 users Like Civilillo's post:5 users Like Civilillo's post
  • sia1, otipca, civilcr, davegabj, malc
Away  joker™
User ID: 10925
Threads: 92
Likes: 7,246 in 938 posts
Given Likes: 2426
10-22-2011, 11:10 AM
Mirror
No limits to creativity
  Portable Ram Advanse Student v3.0 osin 0 6,262 11-22-2010, 01:32 AM
Last Post: osin
