Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 7543:1992 Guide to Durability of buildings and building elements, products and com
01-24-2011, 03:42 PM
BS 7543:1992 Guide to Durability of buildings and building elements, products and components
Author: Technical Committee BDB/1 | Size: 1.47 MB | Format: PDF | Publisher: BSI | Year: 1992 | pages: 48 | ISBN: 0580203700
[Image: 96791960479174497497.jpg]
This British Standard gives guidance on durability, required and predicted service life and design life of buildings and their components and/or parts. It applies primarily to new buildings and their components and/or parts rather than to alterations and repairs. It also gives guidance on presenting information on the service and design life of buildings and their components and/or parts when a detailed brief is being developed.
This British Standard applies to civil engineering projects involving buildings, but only partially to other civil engineering projects such as roads, bridges and dams.
This British Standard does not deal with many aspects of obsolescence, i.e. when buildings or parts of buildings are replaced or altered either to suit different needs and changing conditions including change of use, mandatory requirements or when new products offer better performance without a corresponding increase in cost. It should also be borne in mind that a decision to replace or alter obsolete buildings or their parts may be influenced
by a reassessment of their predicted service lives.
NOTE 1 The titles of the publications referred to in this standard are listed on the inside back cover.
NOTE 2 The numbers in square brackets in the text of this standard refer to the numbered references in Appendix D.
  â€¢ kowheng, blaze, Hengki, Grunf, vvvv, usman, Gabemzaman, Dell_Brett, zrilek, toa011, roaming79, RANA WASEEM, peixoto
Threads: 49
02-14-2013, 12:26 PM
links dead; reposted here:
pass:
  â€¢ Jackass, Dell_Brett, peixoto
  BS 7543:2003 Guide to durability of buildings and building elements, products and ir_71 2 3,129 03-13-2018, 11:22 AM
  BS EN 357:2004 Glass in building. Fire resistant glazed elements with transparent or mybest 2 2,803 04-27-2017, 07:06 PM
Last Post: AtoZmail
  BS EN 15050 2007: Precast concrete products. Bridge elements peixoto 2 3,616 05-21-2014, 08:25 AM
  BS EN 13167:2008 Thermal insulation products for buildings - Factory made cellular gl ir_71 1 2,472 02-26-2013, 08:56 AM
Last Post: arshiakh
  BS EN 13170:2008 Thermal insulation products for buildings - Factory made products of ir_71 0 1,846 12-26-2011, 09:06 AM
  BS EN 13171:2008 Thermal insulating products for buildings - Factory made wood fibre ir_71 0 1,878 12-26-2011, 08:51 AM
  BS EN 13164:2008 Thermal insulation products for buildings - Factory made products of ir_71 0 1,892 12-25-2011, 05:08 PM
