Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 5628 Code of practice for the use of masonry
01-22-2011, 06:40 PM (This post was last modified: 01-22-2011, 06:53 PM by ir_71.)
Author: Subcommittee B/525/6 | Size: 2.91 MB | Format: PDF | Publisher: BSI | Year: 2005 | pages: 80 | ISBN: 0580466825
[Image: 11303114284585907143.jpg]
This Part of BS 5628 gives recommendations for the structural design of unreinforced masonry units of bricks, blocks, manufactured stone, square dressed natural stone, and random rubble masonry.
NOTE The thickness of a wall determined from strength considerations may not always be sufficient to satisfy requirements for other properties of the wall such as resistance to fire, thermal insulation, sound insulation or resistance to damp penetration and reference should be made to BS 5628-3 or BS 5390, as appropriate.
It has been assumed in the drafting of this code that the design of masonry is entrusted to chartered structural or civil engineers or other appropriately qualified persons, for whose guidance it has been prepared, and that the execution of the work is carried out under the direction of appropriately qualified supervisors.
Author: Subcommittee B/525/6 | Size: 1.51 MB | Format: PDF | Publisher: BSI | Year: 2005 | pages: 68 | ISBN: 0580467171
[Image: 33794113321485602311.jpg]
This part of BS 5628 gives recommendations for the structural design of reinforced and prestressed
masonry constructed of brick or block masonry or masonry of manufactured stone or square dressed
natural stone.
NOTE The dimensions of a member determined from strength considerations may not always be sufficient to satisfy requirements
for other properties of the member such as resistance to fire and thermal insulation, and reference should be made to other
appropriate standards.
Author: Subcommittee B/525/6 | Size: 3.93 MB | Format: PDF | Publisher: BSI | Year: 2001 | pages: 132 | ISBN: 0580333000
[Image: 57255972520539400178.jpg]
This part of BS 5628 gives general recommendations for the design, construction and workmanship of
masonry, including materials and components and the main aspects of design, other than structural, which
is covered by BS 5628-1 and -2.
The recommendations in this standard are based on experience of single-leaf and cavity walls with and
without insulation within the cavity.
No specific recommendations for the use of random rubble walling are given, the methods of construction
and appearance of which will vary locally according to the type of stone available and traditional practice.
However, general principles are laid down in this standard.
This standard does not cover the use of natural stone panels as cladding to structural masonry and steel
and concrete frames.
NOTE Recommendations about the use of natural stone panels as cladding to structural masonry and steel and concrete frames are
given in BS 8298.
This standard is not necessarily appropriate to the repair and restoration of old buildings. Guidance on
cleaning and surface repair of masonry built of natural stone, cast stone and brick is given in BS 8221.
This standard does not necessarily cover the use of proprietary systems. The user is referred to the
particular recommendations of any technical approval in this case.
  â€¢ Grunf, oanm2000, usman, Dell_Brett, jcoronellr, Adam Smith, kowheng, toa011, zrilek, roaming79, avge, malc, slowet, Hengki, pubudu1199, peixoto
 Notter
User ID: 20955
Threads: 11
Likes: 294 in 32 posts
Given Likes: 168
11-17-2011, 04:01 AM
Link included:
Use of Masonry:
BS 5628 -2: 1995
BS 5628 -3: 1985
Code of practice for use of masonry:
BS 5628 -1: 1992
BS 5628 -2: 2000
BS 5628 -3: 2001
9.38Mb, *.RAR (pdf rared)
[-] The following 7 users Like Notter's post:7 users Like Notter's post
  â€¢ malc, Dell_Brett, Jackass, vinnunsam, Hengki, monter, zrilek
Threads: 49
02-07-2013, 07:57 AM (This post was last modified: 02-07-2013, 08:51 AM by Dell_Brett.)
try this:
BS 5628-1-1992 - Part 1: Structural use of unreinforced masonry
BS 5628-2-2000 - Part 2: Structural use of reinforced and prestressed masonry
BS 5628-3-2001 - Part 3: Materials and components, design and workmanship
Superseded, Withdrawn
Replaced By PD 6697:2010, BS EN 1996-1-1:2005, BS EN 1996-3:2006, BS EN 1996-2:2006
  â€¢ Dell_Brett, Jackass, peixoto, zrilek, semirigid
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 8,233 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,922 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 10,206 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,431 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,719 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 5,296 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,552 02-17-2021, 11:20 AM
Last Post: temp1366
