Civil Engineering Association eBooks Journals, Papers and Presentations Design of Cold Formed Steel Unequel Angle Compression Members
 darkdkay
Malaysia
User ID: 28752
Threads: 9
Likes: 66 in 10 posts
Given Likes: 107
01-08-2011, 01:52 AM
Author: Ben Young, Ehab Ellobody | Size: 640 KB | Format: PDF | pages: 8 (330-338)
[Image: 38879618558697331554.png]
Presents nonlinear finite element analysis of cold-formed steel unequal angles and comparison of the results obtained with the experimental tests.
[-] The following 8 users Like darkdkay's post:8 users Like darkdkay's post
  â€¢ usman, ISTRAKTURA, blaze, jcbv, nuttapolk, Dell_Brett, oanm2000, kowheng
Threads: 307
01-08-2011, 05:45 PM
👉 CLICK HERE 👈 Uploaded: Jan/08/2011, File Size: 580.51 KB, RAR'd single PDF (paginated, bookmarked, searchable text)
If you like this publication, CivilEA's Team strongly suggest you to buy it! Support the authors!
[-] The following 3 users Like Grunf's post:3 users Like Grunf's post
  â€¢ usman, oanm2000, kowheng
 KhaLed-S.E
Egypt
User ID: 48176
Threads: 39
Likes: 1,063 in 98 posts
Given Likes: 490
10-15-2014, 10:51 PM
links are dead
can you uploaded it again
thanks in Advance :)
  â€¢
  Buckling of built-up compression members in the plane of the connectors asim99 2 7,255 12-12-2014, 04:39 PM
Last Post: Veggeta
  BEHAVIOUR OF STEEL SINGLE ANGLE COMPRESSION MEMBERS AXIALLY LOADED THROUGH ONE LEG asim99 1 5,347 10-15-2014, 11:00 PM
Last Post: KhaLed-S.E
  SCI P129: Building Design using Cold Formed Steel Sections: Fire Protection ir_71 2 7,278 12-18-2013, 08:42 AM
Last Post: bigone
  Review of drilled shaft foundation design of high angle electrical transmission strc. jacs1976 0 3,898 10-07-2013, 04:28 PM
Last Post: jacs1976
  Dynamic Testing of Single- and Double-Story Steel-Sheathed Cold-Formed Steel-Framed S asim99 0 4,244 05-09-2013, 04:35 AM
  Column Tests of Cold-Formed Steel Non-Symmetric Lipped Angle Sections darkdkay 3 7,973 04-09-2013, 08:17 AM
  Use Of Steel Fiber Reinforced Concrete In Structural Members With Highly Complex Stre aslam 1 5,204 04-08-2013, 08:00 AM
