BS 4592, parts 0,1,4 and 5 Industrial type flooring and stair treads
Author: Subcommittee B/208/1 | Size: 0.3 MB | Format: PDF | Publisher: BSI | Year: 2006 | pages: 28 | ISBN: 0580482537
![[Image: 30936450859293060587.jpg]](https://pic.civilea.com/images/30936450859293060587.jpg)
This part of BS 4592 specifies requirements the design, manufacture, supply and installation of industrial type flooring and stair treads for manufacturers and suppliers that are common to parts 1 to 5 of BS 4592, for the design of industrial type flooring, stair treads and protective barriers. In addition to the definitive requirements, this standard also requires the items detailed in Clause 4 to be documented. For compliance with this standard, both the definitive requirements and the documented items have to be satisfied.
NOTE 1 Annex A gives methods of calculation and testing of the strength and deflection of flooring and walkways. NOTE 2 Annex B gives recommendations for installation of floor panels. NOTE 3 Annex C gives details of slip resistance testing. This standard does not cover agricultural uses (see BS 5502). Parts 1 to 5 of BS 4592 give specific requirements additional to those in this part (see Foreword).
Author: Subcommittee B/208/1 | Size: 0.25 MB | Format: PDF | Publisher: BSI | Year: 2006 | pages: 16 | ISBN: 0580482545
![[Image: 20487213221782626492.jpg]](https://pic.civilea.com/images/20487213221782626492.jpg)
This part of BS 4592 specifies requirements for the design, manufacture, supply and installation of metal open bar gratings intended for use in industrial flooring and stair treads. It is not applicable where access to machinery is required, in which case the requirements of BS EN ISO 14122 apply. NOTE For the common requirements for industrial flooring and stair treads, see BS 4592-0. In addition to the definitive requirements, this standard also requires the items detailed in BS 4592-0:2006, Clause 4 to be documented. For compliance with this standard, both the definitive requirements and the documented items have to be satisfied.
Author: Subcommittee B/208/1 | Size: 0.3 MB | Format: PDF | Publisher: BSI | Year: 2006 | pages: 18 | ISBN: 058048257X
![[Image: 35155155112639939774.jpg]](https://pic.civilea.com/images/35155155112639939774.jpg)
This part of BS 4592 specifies requirements for the design, manufacture, supply and installation of glass reinforced plastics (GRP) open bar gratings intended for use in industrial flooring, walkways and stair treads. It is not applicable where access to machinery is required, in which case the requirements of BS EN ISO 14122 apply. NOTE For the common requirements for industrial type flooring and stair treads, see BS 4592-0. In addition to the definitive requirements, this standard also requires the items detailed in BS 4592-0:2006, Clause 4 to be documented. For compliance with this standard, both the definitive requirements and the documented items have to be satisfied.
Author: Subcommittee B/208/1 | Size: 0.3 MB | Format: PDF | Publisher: BSI | Year: 2006 | pages: 20 | ISBN: 0580482588
![[Image: 14907060195937968292.jpg]](https://pic.civilea.com/images/14907060195937968292.jpg)
This part of BS 4592 specifies requirements for the design, manufacture, supply and installation of solid plates in metal, aluminium and glass reinforced plastics (GRP) intended for use in industrial flooring and stair treads It is not applicable where access to machinery is required, in which case the requirements of BS EN ISO 14122 apply. NOTE 1 This standard does not cover agricultural uses (see BS 5502). NOTE 2 For the more common requirements for industrial flooring and stair treads, see BS 4592-0. NOTE 3 The method of test for strength and deflection is given in BS 4592-0:2006, Annex A and information to be supplied at the time of enquiry or order is given in BS 4592-0:2006, Clause 4. In addition to the definitive requirements, this standard also requires the items detailed in BS 4592-0:2006, Clause 4 to be documented. For compliance with this standard, both the definitive requirements and the documented items have to be satisfied.
