STP1463 Advances in Adhesives, Adhesion Science, and Testing
Author: Committee D14 | Size: 4 MB | Format: PDF | Publisher: ASTM | Year: 2005 | pages: 142 |
ISBN: 9780803155077
ISBN: 9780803155077
![[Image: 33178091994607721870.jpg]](https://pic.civilea.com/images/33178091994607721870.jpg)
Eleven peer-reviewed papers focus on new adhesives, particularly from the perspective of the newer test methods emerging to better determine adhesive reliability. Subjects cover:
• Test methods and specification that improve the ability to determine long-term bond durability
• Bonding and debonding of wood products
• Test methods that generate more meaningful material information on adhesive reliability
• Method of measuring viscoelastic behavior of adhesives
• Accurate method of measuring yield strength of adhesives and other materials
• Characterizing fracture properties of adhesive joints under impact loading conditions
• Fracture mechanics applied to adhesive joints
• Coating adhesion testing
• Diffusion of fluids in pressure sensitive adhesives
STP 1463 is a valuable resource for design engineers and those with interest in advanced test methods for adhesive validation
Table of Contents
Adhesive Bonding and Performance Testing of Bonded Wood Products
Frihart C.
A New Low Cost Method For Measuring the Viscoelastic Behavior of Adhesives
Moonay D., McGregor R., Mastria R.
Method for Quantifying Percentage Wood Failure in Block-Shear Specimens by a Laser Scanning Profilometer
Scott C., Hernandez R., Frihart C., Gleisner R., Tice T.
SED Method of Measuring Yield Strength of Adhesives and Other Materials
Lenwari A., Albrecht P., Albrecht M.
Characterizing Dynamic Fracture Behavior of Adhesive Joints under Quasi-Static and impact Loading
Simón J., Johnson E., Dillard D.
Interfacial Diffusion of Fluids in Pressure Sensitive Adhesives
O'Brien E., Ward T.
Advanced Methods of Coating Adhesion Testing
Gitis N., Xiao J., Vinogradov M.
Fracture Mechanics Applied to Adhesive Joints
Wheeler G., Madsen B., DeVries K.
The Study of Bond Strength and Bond Durability of Reactive Powder Concrete
Lee M., Chiu C., Wang Y.
Evaluation of Different Techniques for Adhesive Properties of Asphalt-Filler Systems at Interfacial Region
Huang S., Turner T., Pauli A., Miknis F., Branthaver J., Robertson R.
New Technique for Measuring Extended Viscosity Ranges — Gel Times, Pot Life, or Cure Monitoring — with Programmable Rotational Viscometers or Rheometers
