Civil Engineering Association eBooks Journals, Papers and Presentations The effects of aggregates characteristics on the performance of Portland cement
Threads: 1,298
11-23-2010, 11:06 AM (This post was last modified: 03-05-2015, 12:19 PM by oanm2000.)
The effects of aggregates characteristics on the performance of Portland cement concrete
Author: Pedro Nel Quiroga and David W. Fowler | Size: 7.5 MB | Format: PDF | Publisher: The University of Texas at Austin | Year: 2004 | pages: 382
[Image: 77913401182438648409.jpg]
Aggregate shape, texture, and grading have a significant effect on the performance of fresh concrete. Aggregate blends with well-shaped, rounded, and smooth particles require less paste for a given slump than blends with flat, elongated, angular, and rough particles. At the same time, uniform gradings with proper amounts of each size result in aggregate blends with high packing and in concrete with low water demand. Optimized aggregate blends have high packing, requiring low amounts of paste. As a result, they are less expensive and will have less durability problems caused by the paste such as heat generation, porosity, and drying shrinkage.
Current ASTM C 33 standard limits the amount of material passing the N 200 sieve (microfines) to 7 percent. However, manufactured fine aggregate (MFA) usually has between 10 and 20 percent microfines. These limits, intended for natural sands, force MFA producers to wash aggregate incrementing costs and generating environmental issues. Research at The University of Texas and experience in other countries show that good quality concrete can be made with MFA with high-microfines content.
Many proportioning methods such as ACI 211 do not consider high amounts of microfines, considers partially the effect of shape and texture of aggregates, and do not encourage optimization of aggregate.
The effect of shape, texture and grading of aggregates on fresh concrete was evaluated experimentally, quantified by means a proportioning method based on packing density concepts, the Compressible Packing Model (CPM), and analyzed by an empirical tool suggested by Shilstone. The effect of different types and amounts of microfines was evaluated simultaneously as well as the impact of chemical admixtures and supplementary cementing materials on concrete with high microfines were also evaluated experimentally. It was concluded that chemical admixtures and some supplementary cementing materials can be used to improve the workability of concrete with high microfines without negatively affecting hardened
concrete.
Guidelines for proportioning and optimizing aggregate blends were made based on Shilstone’s Coarseness Chart and the 0.45 Power Chart and CPM equations and procedures.
  • kowheng, kmmh76, pedzaquino, Dell_Brett, blaze, mary, usman, tpipkpo, cigutierrezg, roaming79, sodapas, Umer.Aleem, pmg814, rbmkhtr, lisine, oanm2000
 f_slikken
User ID: 21091
Threads: 13
Likes: 910 in 88 posts
Given Likes: 778
03-05-2015, 11:10 AM
Hi,
[-] The following 8 users Like f_slikken's post:8 users Like f_slikken's post
  • PinkPant, Jackass, lisine, oanm2000, amindoxiti, malc, bridgeengineer, Dell_Brett
 Veggeta
Guatemala
User ID: 114
Threads: 103
Likes: 4,273 in 520 posts
Given Likes: 403
03-06-2015, 04:40 AM
[-] The following 2 users Like Veggeta's post:2 users Like Veggeta's post
  • PinkPant, oanm2000
  Assessment of the Environmental Effects on the Performance of FRP Repaired Steel Pipe asim99 0 3,864 05-21-2013, 07:42 PM
  A high performance fibre reinforced cement based plaster for retrofitting RC members asim99 0 4,459 05-11-2013, 05:57 PM
  Influence of Cellulose Ethers on the Kinetics of Early Portland Cement Hydration ir_71 0 3,959 02-24-2012, 06:23 PM
  Portland Cement Pervious Concrete Pavement datagap 0 4,070 05-06-2011, 11:11 AM
Last Post: datagap
  Rubblization of Portland Cement Concrete Pavements ir_71 1 5,283 03-29-2011, 11:54 AM
Last Post: 3fan
  The Use of Limestone in Portland Cement ir_71 0 3,764 03-26-2011, 06:35 AM
  Solidification and Stabilization of Wastes Using Portland Cement ir_71 0 3,459 03-17-2011, 06:39 PM
