Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Theory of Beam-Columns, Volume 1 : In-Plane Behavior and Design
[Request] Theory of Beam-Columns, Volume 1 : In-Plane Behavior and Design
 igor1234
User ID: 17154
Threads: 38
Likes: 677 in 124 posts
Given Likes: 678
11-08-2010, 09:07 AM (This post was last modified: 11-08-2010, 09:13 AM by Grunf.)
[Image: 12854242732980025472.jpg]
By Wai-Fah Chen & Toshio Atsuta
Softcover, 6x9, 513 Pages
ISBN: 978-1-932159-76-9
November 2007
About the Item:
This is the first volume of a two-volume work presenting the basic theoretical principles, methods of analysis in obtaining the solutions of beam-columns, and developments of theories of biaxially loaded beam-columns, and to show how these theories can be used in the solution of practical design problems. After presenting the basic theory the authors proceed to solutions of particular problems. Both refined and simplified design procedures, along with their limitations, are presented. It is left to the engineer to choose among them as he sees fit.
An unabridged J. Ross Publishing republication of the edition published by McGraw-Hill, Inc., New York, 1976, 513pp.
About J. Ross Publishing Classics
J. Ross Publishing Classics are world-renowned texts and monographs written by preeminent scholars. These books have been widely read, discussed, and cited in the literature since their inaugural publications but unavailable for some time to students, researchers, professionals, and libraries. J. Ross Publishing is proudly making these valuable references and texts available once again.
ISBN 10: 1-932159-76-2
Key Features:
Discusses the complete theory of beam-columns from the most elementary to the most advanced state of development
Various methods of solution are presented which are best suited for the types of beam-column problems
Numerical results are given in terms of tables, charts, and diagrams which furnish values of critical loads for various beam-column problems
About the Author(s):
Dr. Wai-Fah Chen was Professor and Dean of the College of Engineering at the University of Hawaii from 1999 to 2006. From 1976 to 1999, he was Head of the Department of Structural Engineering at Purdue University and George E. Goodwin Distinguished Professor of Civil Engineering; prior to that he taught at Lehigh University. The author of more than 300 peer-reviewed publications and author or co-author of 20 books, his primary areas of research are constitutive modeling of engineering materials, soil and concrete plasticity, structural connections, and structural stability. He received his Ph.D. from Brown University. He is a member of the U.S. National Academy of Engineering and an Honorary member of the American Society of Civil Engineers.
Dr. Toshio Atsuta has been Vice President of the New Industry Research Organization, Kobe, Japan since 2003. The organization was established to revitalize the regional industry damaged through the big earthquake in Kobe in 1995. He graduated from the University of Tokyo in 1963 with his B.S. in Naval Architecture where he worked until 1965 as research associate in Civil Engineering. Then he went to Kawasaki Heavy Industries, Ltd. and worked for the Technical Institute until 2003 when he retired as director of the company. In 1969, Kawasaki sent him to Lehigh University. There he received his M.S. in 1970, and his PhD in 1972, both in Civil Engineering. His doctoral work at Lehigh University covered almost the entire subject of beam-column analysis, i.e., behavior of cross-sections and beam-columns in elastic-plastic regimes under in-plane or biaxial loading conditions.
Table of Contents:
Chapter 1 — Introduction
Chapter 2 — Stress-Strain Relations
Chapter 3 — Elastic Stability of Columns
Chapter 4 — Special Topics in Elastic Stability of Columns
Chapter 5 — Moment-Curvature Relations of Column Segments
Chapter 6 — Plastic Buckling of Columns
Chapter 7 — Analysis of Elastic and Plastic Beam-Columns
Chapter 8 — Deflection Method for Plastic Beam-Columns
Chapter 9 — Curvature Method for Plastic Beam-Columns
Chapter 10 — Curvature Method—Column Curvature Curves
Chapter 11 — Curvature Method—Examples
Chapter 12 — Moment Method and Others for Plastic Beam-Columns
Chapter 13 — Approximate Methods for Ultimate Strength of Beam-Columns
Chapter 14 — Design of Columns and Beam-Columns
Chapter 15 — Probabilistic Analysis of Column Strength
Answers to Some Selected Problems
Author Index
Subject Index
[-] The following 2 users Like igor1234's post:2 users Like igor1234's post
  • david-smith, bigone
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
04-15-2014, 09:36 AM (This post was last modified: 04-15-2014, 02:30 PM by usman.)
here it is
[-] The following 1 user Likes bigone's post:1 user Likes bigone's post
  • zrilek
  [REQUEST] Analysis and design of structural concrete elements subjected to in- plane forces ch_surf 0 1,507 06-23-2014, 03:34 PM
Last Post: ch_surf
  [REQUEST] Shell Structures: Theory and Application: Volume 3 ssobhan 0 1,606 05-17-2014, 04:19 PM
Last Post: ssobhan
  [REQUEST] Analysis of USCD Columns By Modified Compression Theory AlmostThere 0 1,370 05-04-2014, 03:07 PM
Last Post: AlmostThere
  [REQUEST] Partial prestressing, from theory to practice, Volume 1 By M. Z. Cohn aslam 0 1,577 10-14-2010, 02:13 PM
Last Post: aslam
  Design of thin-plated steel box columns under biaxial loading siva_hps 4 3,081 07-16-2010, 11:29 AM
Last Post: siva_hps
