Autodesk Robot Structural Analysis Professional 2011 Build 24.0.4.3539 (x64)
Autodesk Robot Structural Analysis Professional makes available to designers a complete set of tools for calculating building structures of any size and complexity. Engineers can investigate the behavior of designs in both linear and a nonlinear formulation. Interoperability with Autodesk Revit Structure makes a building information model (BIM) is even more informative. Engineers have the ability to perform calculations of various types of designs much faster.
Real 64bit. Downloaded from hotfile and installed. Installed SP4 for x64 too. Multilingual.
![[Image: 07988967192956310309.jpg]](https://pic.civilea.com/images/07988967192956310309.jpg)
π CLICK HERE π
π CLICK HERE π
