Civil Engineering Association eBooks Structural Books Concrete CS TR26: Repair of concrete damaged by reinforcement corrosion
Threads: 1,298
10-20-2010, 06:20 PM (This post was last modified: 12-14-2011, 11:11 PM by usman.)
Concrete Society TR 26 Repair of concrete damaged by reinforcement corrosion
[Image: 83323063967449899314.jpg]
Title
Repair of concrete damaged by reinforcement corrosion, 1984
Publisher
Concrete Society
Camberley, UK
Abstract
The principle factors which cause deterioration of reinforcement are described. Detailed guidance on diagnosis of the cause of corrosion and on inspection and testing is given. The general principles of concrete repair, the stages in the repair process, operation factors and choice of methods are discussed. Guidance is given on the main systems currently used: recasting, sprayed concrete and mortar, hand-applied plain and polymer-modified cementitious mortars; repair of cracks; coatings. Aspects of the conditions of contract, specification and measurement are discussed.
Document Number
Technical Report 26
Document Status
This document is not available from CIS
Subjects
Corrosion and chemical attack, Reinforcement
  • lasalleguy, nuttapolk, bhawk0, kowheng, Dell_Brett, Grunf, chenamoy, roaming79, hmwere, boycv, Ernest0, malc, pram, zrilek
  CS TR?: Assessment, Design and Repair of Fire-Damaged Concrete Stuctures ir_71 6 13,225 08-27-2025, 03:39 AM
Last Post: concreteok
  Corrosion of Steel In Concrete: Understanding, investigation and repair Grunf 12 8,724 12-25-2022, 10:10 PM
Last Post: carolinandra
  CS TR 69 - Repair of concrete structures with reference to BS EN 1504 ir_71 2 3,351 02-06-2022, 12:32 PM
Last Post: babakfeyzi
  Concrete Repair: A Practical Guide cace-01 6 5,396 02-06-2022, 11:44 AM
  Reinforcement Detailing Handbook for Reinforced and Prestressed Concrete carolinandra 0 1,783 01-29-2022, 08:01 PM
  Corrosion and Protection of Reinforced Concrete carolinandra 0 1,611 06-12-2021, 01:49 PM
  Concrete Repair to EN 1504: Diagnosis, Design, Principles and Practice r3be1 3 3,861 11-16-2019, 09:08 AM
