Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general NYDOT: LIQUEFACTION POTENTIAL OF COHESIONLESS SOILS
 tuanpecc1
Vietnam
User ID: 16595
Threads: 63
Likes: 1,427 in 86 posts
Given Likes: 1378
10-16-2010, 02:49 AM (This post was last modified: 01-05-2012, 08:18 PM by usman.)
[Image: 90078752836136701529.png]
Published by NEW YORK STATE DEPARTMENT OF TRANSPORTATION
Date: April 2007
Pages: 80
ABSTRACT
This report provides basic knowledge about liquefaction of cohesionless soils under seismic loading. Presented also are the most widely accepted methods for evaluating the liquefaction potential of cohesionless oils in level ground, for estimating earthquake-induced settlements and for analyzing slope stability against flow slides. Sample problems to demonstrate each design procedure are included in the appendices.
A brief review is presented of the seismicity of New York State, the level of which can be characterized as moderate. The State historically has experienced earthquakes up to a magnitude of 6.0. Earthquakes of this magnitude can cause structural and ground failures from liquefaction. Liquefaction-induced failure types and factors affecting liquefaction susceptibility are also reviewed.
Finally, methods for improving in-situ soil conditions to reduce liquefaction susceptibility are discussed.
[-] The following 18 users Like tuanpecc1's post:18 users Like tuanpecc1's post
  • kowheng, yucapareja, isurya, elitvdis, salahcivil, Grunf, cace-01, fashion, oanm2000, Dell_Brett, kaci, cristi, Svetoslav, gibran, Evandrojr, jaejeong, peymanlord, alibouafia
  NYDOT: ROCK SLOPE RATING PROCEDURE tuanpecc1 0 2,045 10-20-2010, 03:31 PM
Last Post: tuanpecc1
  NYDOT: Bank and channel protective lining design procedures tuanpecc1 0 1,901 10-20-2010, 02:58 PM
  NYDOT: MECHANICALLY STABILIZED EARTH SYSTEM INSPECTION MANUAL tuanpecc1 0 2,002 10-20-2010, 02:24 PM
  NYDOT: COMPUTATION OF SKIN FRICTION ON DRIVEN NONTAPERED PILES IN COHESIONLESS SOIL tuanpecc1 0 2,028 10-19-2010, 04:17 PM
  NYDOT: GEOTECHNICAL DESIGN PROCEDURE FOR FLEXIBLE WALL SYSTEMS tuanpecc1 0 2,128 10-18-2010, 02:56 PM
  NYDOT: GROUND ANCHOR INSPECTOR'S MANUAL tuanpecc1 0 2,053 10-16-2010, 01:53 PM
  NYDOT: GUIDELINES FOR EMBANKMENT CONSTRUCTION tuanpecc1 0 2,031 10-16-2010, 01:35 PM
