Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Nonlinear Static Analysis of a Multistory Plane Frame
 88FeNIX
User ID: 24521
Threads: 39
Likes: 229 in 52 posts
Given Likes: 303
09-28-2010, 09:51 AM
Dear All,
I am doing some research relating to story ductility ratios. I am using Sap2000. The problem is that i have to carry out a lot of iterations and hit and trials. I needed to know is there any simplified software or excel sheet which i can modify.
Thanks.
 Sumatra
User ID: 14369
Threads: 103
Likes: 1,925 in 240 posts
Given Likes: 1580
09-28-2010, 01:06 PM
Dear 88FENIX,
You can employ batch file control in file menu for large number analysis run using sap2000/etabs so that you dont need to hit and run for hundred times. However, the problem may then arise from retrieving the output data (post-processing).
I suggest you to use DOS-based program such as IDARC2D and Ruaumoko, or perhaps OpenSees, for parametric analysis that dealing with large number of analysis run. It is because the retrieving of output data is easy to manage.
Cheers.
[-] The following 2 users Like Sumatra's post:2 users Like Sumatra's post
  • elbarto_87, parhyang
 neikrof
User ID: 12894
Threads: 1
Likes: 111 in 16 posts
Given Likes: 133
09-28-2010, 02:12 PM
Dear 88FENIX,
OAPI (Open Application Programming Interface) for SAP2000 could be helpful in your case. Using OAPI, you can almost totally manage your SAP from an Excel file (automatically create a model - analyze - read analysing results). The basic requirement is you must know a little bit about Visual Basic (SAP and Excel also.)
If you choose OAPI, the SAP2000_API_Documentation.chm available in the SAP installation folder which contains a range of wonderful sample codes could be copied and adjusted to fit your needs.
For more information (introduction - tutorial video), you can go to the CSi site with the keyword "OAPI".
[-] The following 2 users Like neikrof's post:2 users Like neikrof's post
  • 88FeNIX, RANA WASEEM
  Static and Dynamic Analysis of Nonlinear Plane Structures 88FeNIX 3 6,963 09-24-2010, 05:56 AM
Last Post: 88FeNIX
  [HELP] NonLinear Dynamic Analysis using SAP2000 v14.1 anez_regar 3 8,450 05-30-2010, 12:34 PM
Last Post: anez_regar
  SAP2000: how to use NL-Link element for nonlinear analysis Sumatra 0 4,990 03-18-2010, 06:22 AM
Last Post: Sumatra
