Civil Engineering Association eBooks Journals, Papers and Presentations GROUND SUPPORT – REINFORCEMENT, COMPOSITE STRUCTURES
 giguni
User ID: 20677
Threads: 73
Likes: 208 in 33 posts
Given Likes: 166
09-24-2010, 02:38 PM
Ground support comprises a wide field of geotechnical engineering. Therefore some special topics are selected: Reinforcement and dowelling of soil and rock by nails, anchors, piles and jet-grouting. Thus, the ground becomes more or less a compound body which locally can be considered a quasi-monolith. In the case of retaining structures or underground excavations, prestressed anchors are used in addition to conventional reinforcement. The paper focuses on retaining structures, underpinning of buildings, and tunnelling. Residual shear strength of the ground is considered an essential value for parametric design analyses and risk assessment, and the observational method is favoured over the fully-engineered design.
[Image: 03235057462527810873.jpeg]
[-] The following 9 users Like giguni's post:9 users Like giguni's post
  • elitvdis, maad59, tuanpecc1, Dell_Brett, ziggywas1, oanm2000, nhim4mat2006, peymanlord, fer962933
  Repairing Structures Using Composite Wraps i_kabir 1 4,605 08-01-2014, 08:27 AM
Last Post: ssobhan
  Composite Structures [ScienceDirect] foxxx2010 21 28,093 05-08-2012, 09:06 AM
Last Post: mybest
  TTM Ground Anchors, Geotechnical and ground anchor system ir_71 0 4,998 06-24-2011, 06:16 PM
  Guide for the use of stainless steel reinforcement in concrete structures ir_71 0 4,510 12-08-2010, 02:16 PM
  RECENT ADVANCES IN GROUND ANCHOR AND GROUND REINFORCEMENT TECHNOLOGY giguni 0 5,210 09-27-2010, 02:38 PM
Last Post: giguni
  Effects of Transverse Reinforcement and Bonded length on the Side-Blowout Capacity of Headed Reinforcement yucapareja 1 5,988 04-29-2010, 03:14 AM
Last Post: zbizafar
