Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Generating of area spring support in SOFISTIK
 blaze
User ID: 13836
Threads: 5
Likes: 2 in 2 posts
Given Likes: 14624
09-23-2010, 01:03 PM
Dear All,
I have a problem with generating area springs in SOFISTIK via SOFIPLUS.
Does anybody know how to make structure that is supported with springs generated according to support coefficient method (MN/m3) or stiffness coefficient method? I need to support plate or foundation. I dont need support of edges or clear spring.
Thanks in advance.
 leonp
User ID: 10563
Likes: 1 in 1 posts
Given Likes: 0
09-23-2010, 02:12 PM
The quickest way is to add bedding coef. at your area elements (sofimsha) or at your structural areas (sofimshb).
Otherwise your could add manually springs at the nodes or via teddy with sbox command.
Another way is to define bedding coef. at your material.
[-] The following 1 user Likes leonp's post:1 user Likes leonp's post
  • blaze
  Pile as spring below foundation bhowmik 25 38,486 03-19-2010, 11:10 AM
Last Post: Sumatra
