Civil Engineering Association eBooks Journals, Papers and Presentations SEISMIC BEHAVIOUR OF BEAM - COLUMN JOINT.
 jonamcivil
User ID: 9534
Threads: 42
Likes: 163 in 27 posts
Given Likes: 54
09-19-2010, 06:28 PM
SEISMIC BEHAVIOUR OF BEAM COLUMN JOINTS IN REINFORCED CONCRETE MOMENT RESISTING STRUCTURES.
THIS IS TECHNICAL PAPER SUBMITED BY THE IIT PROFESSORS REGARDING THE SEISMIC BEHAVIOUR OF COLUMN - BEAM JOINT.
[-] The following 5 users Like jonamcivil's post:5 users Like jonamcivil's post
  â€¢ szepj, kowheng, valinhas, barukai, Haseeb Jamal
  Seismic soil – pile – structure kinematic and inertial interaction — Anew beam approa TAFATNEB 0 4,677 08-12-2014, 01:28 PM
  A NEW MODEL FOR JOINT SHEAR FAILURE OF REINFORCED CONCRETE INTERIOR BEAM-TO-COLUMN JO TAFATNEB 0 4,087 06-01-2014, 03:35 PM
  Seismic Behaviour and Retrofit of Historic Masonry Minaret TAFATNEB 0 4,435 12-12-2013, 08:06 PM
  Seismic behaviour estimation of thin alluvium layers using microtremor recordings arshiakh 0 3,638 04-26-2013, 07:48 PM
Last Post: arshiakh
  Strengthening of Reinforced Concrete Beam-Column Joints eng2010 1 6,844 01-14-2013, 07:00 AM
  Finite element analysis of steel beam to column connections lisine 0 4,179 11-08-2012, 04:18 PM
  SEAOC Strong-column/weak-beam RedHorse 1 6,672 06-28-2011, 02:32 PM
Last Post: Jackass
