Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Staad Plate
Staad Plate
 zbizafar
User ID: 1998
Threads: 57
Likes: 889 in 86 posts
Given Likes: 333
07-01-2010, 08:02 AM
I am having problem analysis a 600 x 600 x 10 mm plate in staad. with only self wt the stress are so high. I am attaching the staad input file, please check and inform what i am doing wrong.
The plate is intended to be a chequered plate cover over underground Pit.
Staad Plate
[Image: 72248410582195005212.jpg]
 triance
Bangladesh
User ID: 11351
Threads: 21
Likes: 250 in 35 posts
Given Likes: 687
07-01-2010, 08:46 AM
I saw the model and didn,t find any problem. You have to choice which result you want. Here are some fig to explain staad plate result.
[Image: 83708703919839107980.jpg]
[Image: 44600074212933457787.jpg][Image: 06340803732022944351.jpg][Image: 51455109612719140654.jpg]
[-] The following 1 user Likes triance's post:1 user Likes triance's post
  • zbizafar
 zbizafar
User ID: 1998
Threads: 57
Given Likes: 333
07-01-2010, 09:30 AM
I have attached the absolute value from staad, i know you can check for different stresses but i can't understand how a 600 mm long plate with self wt only can have such high stress values. if you see in the model almost all stresses are very high. Maybe i am looking at it in a wrong way but i am confused.
Thanks,
 zbizafar
User ID: 1998
Threads: 57
Given Likes: 333
07-03-2010, 11:44 AM
I am sure many people here know the solution to the problem, please make time and reply.
Thanks
 seb3k
User ID: 7801
Threads: 5
Likes: 147 in 63 posts
Given Likes: 156
07-03-2010, 11:15 PM
You made an error in syntax while adding self weight load
it should be:
LOAD 1 LOADTYPE None TITLE SELF WT
SELFWEIGHT Y -1
replace theese 2 lines, keep everything else the same and it works perfectly (ran it in staad2007).
deflection is about 0.02mm
[-] The following 1 user Likes seb3k's post:1 user Likes seb3k's post
  • zbizafar
