REVIT MEP SUITE VERSION 2010
AUTODESK
[img]c:\revitmep.jpg[/img]
AUTODESK
AutoCAD Revit MEP Suite combines Autodesk Revit MEP building information
modeling (BIM) software with the widely used AutoCAD® MEP software.
This solution enables you to work in a familiar AutoCAD-based environment with
AutoCAD MEP, while gaining the competitive advantages of BIM with Autodesk Revit MEP
to support better decision making. Improve your drafting productivity and move to BIM
at your own space.
