Civil Engineering Association eBooks Structural Books Concrete RC Infilled Frame-RC Plane Frame Interactions for Seismic Resistance
 ivanveliki
User ID: 1250
Threads: 47
Likes: 886 in 110 posts
Given Likes: 480
04-22-2009, 06:30 PM
Journal of Applied Sciences
Year: 2007 | Volume: 7 | Issue: 7 | Page No.: 942-950
DOI: 10.3923/jas.2007.942.950
Suyamburaja Arulselvan , K. Subramanian , E.B. Perumal Pillai and A.R. Santhakumar
Abstract: Experimental investigation was planned and conducted to study the influence of brick masonry infill in a reinforced cement concrete frame. The analytical methods available needs validation by comparison with experimental results and more accurate methods of analysis like finite element analysis has to be used for the above purpose. In this study, RC frame with middle bay brick infilled representing a five-stories, three bay building in quarter-scale has been taken for experimental investigation and the available methods of theoretical analysis and finite element analysis using ANSYS software for the frames have been carried out. Until the cracks developed in infills, the contribution of the infill to both lateral stiffness and strength was very significant. The change in lateral stiffness, strength, ductility and natural period of the framed structure due to the presence of infills change the behaviour of the building under seismic action. The object of this study was to investigate the behaviour of such infilled frames under seismic loads. For this purpose, five stories, three bay frames with central portion infilled with brick were tested under static cyclic loading simulating seismic action. Analytical works was done to understand the stiffness, strength and behaviour of these types of frames.
[-] The following 8 users Like ivanveliki's post:8 users Like ivanveliki's post
  • Administrator , Administrator , muki5, user, cristi, Nilupa, tospol, pedzaquino
  Static and dynamic analysis of a reinforced concrete flat slab frame building for pro gulilero 2 2,851 05-18-2016, 06:24 AM
Last Post: subin91
  PowerPoint "Seismic Performance Assessment of RC Moment Resisting Frame Building" benny 4 5,819 12-25-2013, 06:04 PM
Last Post: scorpion07
  The Seismic Performance of Reinforced Concrete Frame Buildings oanm2000 2 3,134 07-12-2012, 07:40 AM
Last Post: Grunf
  Econmic Concrete Frame Elements ir_71 2 2,637 06-13-2012, 06:58 AM
Last Post: ykhackhack
  Precast Concrete Frame Buildings - Design Guide babak 2 4,479 06-13-2012, 06:55 AM
Last Post: psppsp
  Innovation in concrete frame construction 1995-2015 bashir999 1 2,291 05-14-2011, 10:09 PM
Last Post: 3fan
  The Equivalent Frame Analysis for Reinforced Concrete Slabs parhyang 0 2,064 11-24-2010, 06:55 AM
Last Post: parhyang
