Civil Engineering Association eBooks Journals, Papers and Presentations Modeling of Masonry Infill Panels for Structural Analysis
 aslam
Abu Dhabi
User ID: 64
Threads: 284
Likes: 7,707 in 755 posts
Given Likes: 2168
03-11-2009, 12:05 PM (This post was last modified: 10-15-2010, 07:07 AM by Grunf.)
A Madan, A M Reinhorn, J B Mander, R E Valles
JOURNAL OF STRUCTURAL ENGINEERING (1997)
Volume: 123, Issue: 10, Pages: 1295-1302
Abstract:
An analytical macromodel based on an equivalent strut approach integrated with a smooth hysteretic model is proposed for representing masonry infill panels in nonlinear analysis of frame structures. The hysteresis model uses degrading control parameters for stiffness and strength degradation and slip "pinching" that can be implemented to replicate a wide range of hysteretic force-displacement behavior resulting from different design and geometry. The paper presents the development of the hysteretic model and the definitions of the control parameters, which can be determined using any suitable theoretical model for masonry infills. An available theoretical model for simplified engineering evaluation of masonry infilled frames was explored for estimating the control parameters of the proposed macromodel. The macromodel was incorporated in a nonlinear structural analysis program, IDARC2D Version 4.0, for quasi-static cyclic and dynamic analysis of masonry infilled frames. Simulations of experimental force-deformation behavior of prototype infill frame subassemblies are performed to validate the proposed model. A lightly reinforced concrete frame structure is analyzed for strong ground motions to evaluate the influence of masonry infill panels on the dynamic response.
[-] The following 7 users Like aslam's post:7 users Like aslam's post
  â€¢ ptcruiser, ptcruiser, orambo, orambo, KAMM, KAMM, Grunf
 kvtasp
User ID: 7690
Threads: 60
Likes: 2,028 in 379 posts
Given Likes: 791
01-29-2012, 07:06 AM
[-] The following 8 users Like kvtasp's post:8 users Like kvtasp's post
  â€¢ 3fan, kowheng, malc, slowet, Jackass, sructme, Hengki, learner20
  Effect of modeling range on structural analysis for powerhouse of hydroelectric power arshiakh 0 3,786 01-20-2014, 07:53 AM
Last Post: arshiakh
  Implications of vertical mass modeling errors on 2D dynamic structural analysis asim99 0 3,980 12-29-2012, 12:16 AM
  Small-Scale Modeling of Reinforced Concrete Structural Elements for Use DamirDz 1 5,436 11-17-2012, 01:28 PM
Last Post: mybest
  An equivalent frame model for seismic analysis of masonry and reinforced concrete bui Veggeta 0 3,634 03-31-2011, 05:51 PM
Last Post: Veggeta
  Non-linear seismic analysis and vulnerability evaluation of a masonry building SAP2k hazus 0 5,199 07-14-2010, 08:05 PM
Last Post: hazus
