Civil Engineering Association eBooks Traffic Engineering The Effects of Higher Strength and Associated Concrete Properties on Pavement Perform
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,039 in 2,189 posts
Given Likes: 42508
12-09-2009, 12:57 AM (This post was last modified: 03-03-2012, 11:39 AM by kowheng.)
The Effects of Higher Strength and Associated Concrete Properties on Pavement Performance
[Image: 56837311685884105117.gif]
This report documents the investigation of the effect of strength and other associated concrete properties of the long-term performance of concrete pavements. Performance criteria used included joint spalling, faulting and transverse slab cracking. Project variables included pavement age, traffic, climate, distress levels and types, joint spacing and compressive strength. Compressive strength was found to correlate well with permeability. Concrete characteristics found to be desirable include compressive strength in the 45 to 50 MPa range, flexural strength in the 4.5 to 6.0 range, non-alakali reactive aggregate that is freeze-thaw distress resistant, a well- graded aggregate with large top size, water-cement ratio of 0.42 to 0.45 and cement content of approximately 335 kg/m3.
Prototype mixture designs were developed for different climatic regions. This report will be of interest to those involved in concrete pavement mixture design, as well as those involved in the design, construction and analysis of concrete pavements.
Sufficient copies are being distributed to provide 10 copies to each FHWA Resource Center, five copies to each FHWA Division, and five copies to each State highway agency. Direct distribution is being made to the FHWA Division Offices. Additional copies may be purchased from the National Technical Information Service (NTIS), 5285 Port Royal Road, Springfield, Virginia 22161.
[Image: 49560126338157243590.gif]
[-] The following 13 users Like Dell_Brett's post:13 users Like Dell_Brett's post
  â€¢ kowheng, zrilek, Grunf, oanm2000, Ultra Zone, henrycv, giovas, arief_gond, cristi, jf28, rudyhera03, fer962933, blaze
  Concrete Pavement Design, Construction, and Performance Grunf 14 10,591 10-23-2015, 05:48 PM
Last Post: ibg0203
  Advances in Pavement Design through Full-scale Accelerated Pavement Testing cace-01 4 3,308 01-26-2015, 03:50 AM
Last Post: gulilero
  Finite Element Evaluation of Pervious Concrete Pavement for Roadway Shoulders mahyarov 0 1,929 11-17-2012, 12:34 PM
Last Post: mahyarov
  Final Report for Early-Opening-to-Traffic Portland Cement Concrete for Pavement Rehab mahyarov 0 1,672 10-25-2012, 06:17 PM
Last Post: mahyarov
  Environmental Effects in Pavement Mix and Structural Design Systems mahyarov 0 1,602 10-25-2012, 04:00 PM
Last Post: mahyarov
  Contributions of Pavement Structural Layers to Rutting of Hot-Mix Asphalt Pavement mahyarov 0 1,814 10-24-2012, 10:59 AM
Last Post: mahyarov
  Guidelines for Early-Opening-to-Traffic Portland Cement Concrete for Pavement Rehabil mahyarov 0 1,650 10-24-2012, 06:54 AM
Last Post: mahyarov
