Civil Engineering Association Software Software Product Autodesk Products DWG TrueView CAD 2010
Threads: 1,118
11-28-2009, 06:18 AM
DWG TrueView CAD file conversion software includes DWG TrueConvert™ translation software for translating any AutoCAD design application or AutoCAD-based drawing file for compatibility.
DWG TrueView™ software, the free* AutoCAD® design viewer. Use DWG TrueView to view, plot, and publish DWG™ and DWF™ files and convert AutoCAD®-based files for compatibility.
System Requirements
For 32-bit DWG TrueView 2010
Microsoft® Windows Vista® (SP1 or later), Microsoft® Windows® XP (SP2 or later)
Intel® Pentium® 4 or AMD Athlon® dual-core processor, 1.6 GHz or faster (3.0GHz or faster for Windows Vista)
Microsoft® .NET Framework 3.5 (SP1 or later) and Microsoft DirectX® pre-installed*
512 MB RAM (1 GB RAM for Windows Vista)
550 MB free disk space for installation
1,024 x 768 VGA with true color
Microsoft® Internet Explorer® 7.0
For 64-bit DWG TrueView 2010
Windows Vista 64-bit (SP1 or later) or Windows XP Professional x64 Edition (SP2 or later)
AMD64 or Intel EM64T processor
Microsoft .NET Framework 3.5 (SP1 or later) and DirectX pre-installed*
2 GB RAM
Internet Explorer 7.0
Note: 64-bit DWG TrueView™ software cannot be installed on a 32-bit Windows operating system.
*To use DWG TrueView 2010, you must first install Microsoft .NET Framework 3.5 (SP1 or later) and DirectX on your system. See Microsoft .NET Framework 3.5 download center to download .NET 3.5.
[Image: 59585409362314568642.gif]
Seeing the request of some user to upload again an autocad file in an earlier format i understand that maybe not all users know this free utility of Autodesk. This is the last version and every one can download it for converting dwg files (in batch mode too).
Don't forget - the Autocad versions 2000 and 2002 use the 2000 format, 2004, 2005. 2006 the 2004 format and from 2007 until 2010 the 2007 format.
  • Dell_Brett, bybyby, deepam02, pelelo, bhawk0, javedadam
