Civil Engineering Association eBooks Codes, Manual & Handbook ACI [CivilEA Exclusive] ACI PRC-440.14-25: Design of Circular Concrete-Filled Fiber-Reinforced Polymer Tubes
Likes: 8,311 in 1,373 posts
Given Likes: 94
08-17-2025, 10:25 AM (This post was last modified: 08-17-2025, 10:25 AM by poolmand.)
Author(s)/Editor(s): ACI Committee 440| Format: PDF| Quality: Scanner| Year: 2025| pages: 20 | ISBN: 9781641953160
[Image: do.php?img=2]
The circular concrete-filled fiber-reinforced polymer (FRP) tube (CFFT) system is an alternative to traditional reinforced concrete structures. The pre-cured FRP tube, which comprises layers of engineered fibers oriented in different directions, provides a corrosion-resistant stay-in-place structural form to retain freshly cast concrete that speeds up construction while at the same time provides primary reinforcement in the two orthogonal directions instead of traditional longitudinal steel reinforcing bar, ties, and stirrups. Typical applications of CFFT include piles, columns, and poles used in building and bridge construction. The FRP tube provides confinement and environmental protection of the concrete core, increasing its strength, ductility, and durability, as well as protection of the minimum internal steel reinforcement. Due to the unique characteristics of CFFTs in which reinforcement in the orthogonal directions are integrated into one continuous membraneβ€”namely, the tubeβ€”specific guidance on the design of members using this system is needed. This guide provides general information and background of CFFT technology, including applications and limitations, characteristics of circular FRP tubes, and the interface bond between tube and concrete. The guide provides provisions for design for flexure, axial load, shear, combined loading, connections, and a design approach aimed at mitigating the risk of accidental tube loss. This guide is based on the knowledge gained from experimental research, analytical work, and field applications of CFFTs.
bond; circular; concrete-filled fiber-reinforced polymer tube (CFFT); confinement; connections; fiber-reinforced polymer (FRP); stay-in-place form; tube.
  β€’ subin91, Dell_Brett
  [CivilEA Exclusive] ACI 548.17: Circular Precast Polymer-Concrete Manholes poolmand 0 908 12-06-2025, 10:50 AM
  [CivilEA Exclusive] ACI 440.13: Strengthening Structural Concrete with Fiber-Reinforced Polymer (FRP) Sys poolmand 0 2,070 12-15-2024, 06:43 AM
  ACI E702.7: Designing Concrete Structures: Carbon Fiber-Reinforced Polymer (CFRP) She poolmand 0 1,595 08-28-2024, 06:01 AM
  ACI E702.5: Designing Concrete Structures: Slender Reinforced Concrete Wall Design - poolmand 0 1,678 08-28-2024, 05:32 AM
  ACI 343: Analysis and Design of Reinforced Concrete Bridge Structures noelda2 3 5,240 05-12-2024, 10:46 AM
  ACI SP-360: Proceedings of the 16th International Symposium on Fiber-Reinforced Polym poolmand 0 1,727 04-16-2024, 10:16 AM
  ACI SP-344: Examples for the Design of Reinforced and Prestressed Concrete Members Un poolmand 0 1,892 03-04-2024, 08:35 AM
