Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) ISO 22762-2: Elastomeric seismic-protection isolators Part 2: Applications for bridge
Likes: 8,311 in 1,373 posts
Given Likes: 94
11-16-2024, 01:21 PM
ISO 22762-2:2024 Elastomeric seismic-protection isolators Part 2: Applications for bridges — Specifications
| Size: 14.52 MB| Format: PDF| Quality: Scanner| Year: 2024-09| pages: 55
[Image: 48313322016099202688.jpg]
This document specifies minimum requirements and test methods for elastomeric seismic isolators used for bridges, as well as rubber material used in the manufacture of such isolators.
It is applicable to elastomeric seismic isolators used to provide bridges with protection from earthquake damage. The isolators covered consist of alternate elastomeric layers and reinforcing steel plates, which are placed between a superstructure and its substructure to provide both flexibility for decoupling structural systems from ground motion and damping capability to reduce displacement at the isolation interface and the transmission of energy from the ground into the structure at the isolation frequency.
  • babakfeyzi, Dell_Brett
  ISO/TR 22762-7: Elastomeric seismic-protection isolators Part 7: Relationship of the poolmand 0 3,017 11-17-2024, 06:52 AM
  ISO 22762-6: Elastomeric seismic-protection isolators Part 6: High-durability and hig poolmand 0 2,929 11-17-2024, 06:50 AM
  ISO 22762-5: Elastomeric seismic-protection isolators Part 5: Sliding seismic-protect poolmand 0 2,968 11-17-2024, 06:47 AM
  ISO/TS 22762-4: Elastomeric seismic-protection isolators Part 4: Guidance on the appl poolmand 0 2,991 11-17-2024, 06:44 AM
  ISO 22762-3: Elastomeric seismic-protection isolators Part 3: Applications for buildi poolmand 0 3,001 11-16-2024, 01:25 PM
  ISO 22762-1: Elastomeric seismic-protection isolators Part 1: Test methods poolmand 0 3,031 11-16-2024, 01:18 PM
  BS EN 10305 part 1 to part 6- Steel tubes for precision applications mybest 0 2,119 11-28-2011, 06:48 AM
Last Post: mybest
