Civil Engineering Association Software Software Product Bentley Products Bentley ProStructures 2024
Likes: 8,311 in 1,373 posts
Given Likes: 94
10-05-2024, 06:11 AM
Bentley ProStructures CONNECT Edition 2024.0.0.37 x64
What is ProStructures?
ProStructures, the steel and concrete design software includes both ProSteel and ProConcrete.
Model concrete structures
Model parametric reinforced concrete objects of any shape, with any combination of reinforcing
Easily create concrete structures for buildings, plants, civil projects, and bridges
Reduce documentation time and eliminate errors
Create 3D models, placement drawings, fabrication details, bar bending schedules, concrete quantity, and material reports
Automatically perform updates to reflect model changes
Produce high-quality steel detailing and fabrication designs
Develop models and documentation for steel structures efficiently
Confidently deliver an accurate 3D model for steel structures and extract engineering, fabrication, and erection drawings
Leverage automatic updates whenever the 3D model is changed
Produce drawings for every steel shape, connection, and plate-work from the 3D model
Generate and update in-drawing, external reports, and bills of material
[Image: comments.png]
**Installation Guide (Translated)**
1. Install the software.
2. After installation is complete, ensure all Bentley CONNECTION services are closed. Make sure the Bentley CONNECTION Client is not running by checking the system tray (near the Windows clock).
3. Uninstall the Bentley CONNECTION Client via Control Panel --> Programs --> Add or Remove Programs (or Programs and Features).
4. Run the file `Setup_CONNECTIONClientx64_23.00.00.10.exe` from the Crack folder to install the new connection client.
5. Ensure the Bentley CONNECTION Client is not running by checking the system tray again.
6. Copy the `Patch.exe` file from the Crack folder to the software installation directory. Right-click on it and select "Run as Administrator." Enter the following credentials when prompted and wait for the patch to complete:
- **Name**: lavteam.org
- **Password**: 95F01D00-5A3E1708-953B3024-117D8F6F
7. The software is now activated and can be used without any restrictions.
  â€¢ zrilek
 mmikli2
Slovenia
User ID: 181923
Likes: 0 in 0 posts
Given Likes: 0
01-21-2025, 08:03 PM
Links are dead. Can you reload softwere? Thank you
  â€¢
Given Likes: 94
02-01-2025, 10:44 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
  â€¢ zrilek, oanm2000, lisine, Dell_Brett
  Bentley MicroStation 2024 poolmand 0 3,334 10-05-2024, 10:18 AM
  Bentley STAAD.Pro Advanced 2024 poolmand 0 5,733 09-15-2024, 06:01 AM
  Bentley OpenFlows SewerGEMS 2024 poolmand 0 4,002 06-26-2024, 07:23 AM
  Bentley OpenFlows CivilStorm 2024 poolmand 0 4,155 05-12-2024, 07:37 AM
  Bentley ProStructures CONNECT Edition Update 5.2 (10.05.02.50) x64 poolmand 0 4,457 10-19-2021, 12:01 PM
  Bentley ProStructures V8i SS8 08.11.14.195 TAFATNEB 0 6,431 10-06-2016, 11:43 AM
  Bentley Power ProStructures V8i SS7 08.11.11.616 ibg0203 0 6,048 09-23-2015, 05:06 PM
Last Post: ibg0203
