Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI RAP-2: Crack Repair by Gravity Feed with Resin
Likes: 8,311 in 1,373 posts
Given Likes: 94
08-28-2024, 06:32 AM
Author(s)/Editor(s): ACI Committee E706| Format: PDF| Quality: Original preprint| Year: 2011
[Image: 47490797890273195445.png]
Field Guide to Concrete Repair Application Procedures
This topical application for crack repair uses a thin polymer resin to fill the crack. Penetrating by gravity alone, the resin fills the crack and forms a polymer plug that seals out water, salts, and other aggressive elements. In some cases, a structural repair of the crack can be achieved. Before any concrete is repaired, the cause of the damage must be assessed and the objective of the repair must be
understood.
Typical causes of concrete cracking include steel corrosion, freezing and thawing, sulfate attack, and alkali-aggregate reaction (AAR). Poor practices during the original construction can cause excessive shrinkage or settlement in the structure. Improper joint spacing and load imbalances also contribute to cracking.
  â€¢ babakfeyzi
  ACI RAP-1: Structural Crack Repair by Epoxy Injection poolmand 0 2,055 08-28-2024, 06:30 AM
  ACI 548.15: Specification for Crack Repair by Epoxy Injection poolmand 0 1,637 11-23-2021, 05:15 AM
