Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI E702.7: Designing Concrete Structures: Carbon Fiber-Reinforced Polymer (CFRP) She
Likes: 8,311 in 1,373 posts
Given Likes: 94
08-28-2024, 06:01 AM
ACI E702.7-22 Designing Concrete Structures: Carbon Fiber-Reinforced Polymer (CFRP) Shear Strengthening
Author(s)/Editor(s): ACI Committee E702| Format: PDF| Quality: Original preprint| Year: 2022
[Image: 07069659960582054231.png]
The design example, “Carbon Fiber Reinforced Polymer (CFRP) Shear Strengthening,” works through calculations for a one way slab with an interior beam that requires shear strengthening. The example follows the provisions of ACI CODE 318-19, “Building Code Requirements for Structural Concrete and Commentary.”
ACI Committee E702, “Designing Concrete Structures Committee,” is part of the ACI Educational Committee structure. Their mission is to develop educational programs and instructional materials within the area of design. The committee has developed various design examples to illustrate the use of various ACI documents. These examples provide step-by-step calculations with references to applicable code provisions for common member design problems, and may also include calculations for common concrete testing procedures, field data analysis, or evaluations.
  • babakfeyzi, lisine
  [CivilEA Exclusive] ACI 548.17: Circular Precast Polymer-Concrete Manholes poolmand 0 908 12-06-2025, 10:50 AM
  [CivilEA Exclusive] ACI PRC-440.14-25: Design of Circular Concrete-Filled Fiber-Reinforced Polymer Tubes poolmand 0 2,451 08-17-2025, 10:25 AM
  [CivilEA Exclusive] ACI 440.13: Strengthening Structural Concrete with Fiber-Reinforced Polymer (FRP) Sys poolmand 0 2,071 12-15-2024, 06:43 AM
  [CivilEA Exclusive] ACI 323: Low-Carbon Concrete - Code Requirements and Commentary poolmand 0 2,580 12-15-2024, 05:50 AM
  ACI E702.9: Designing Concrete Structures: Reinforced Rectangular Concrete Column Int poolmand 0 1,668 08-28-2024, 06:13 AM
  ACI E702.8: Designing Concrete Structures: Evaluation of Concrete Cores Test Results poolmand 0 1,589 08-28-2024, 06:12 AM
  ACI E702.6: Designing Concrete Structures: Design a Concrete Floor System using the P poolmand 0 1,685 08-28-2024, 05:34 AM
