CSA S806:12 (R2021) Design and construction of building structures with fibre-reinforced polymers
| Size: 19 MB| Format: PDF| Quality: Scanner| Year: 2012 (R2021)| pages: 201
![[Image: 02105734009352658982.jpg]](https://pic.civilea.com/images/02105734009352658982.jpg)
This is the second edition of CSA S806, Design and construction of building structures with fibre-reinforced polymers. It supersedes the first edition published in 2002.
This Standard contains provisions for building structures composed of fibre-reinforced polymers (FRP). The fibres are of aramid, carbon, and glass. The polymers are resins that are rigid at room temperature; relevant provisions relate to thermosetting types of resin. The Standard covers general design requirements, limit states design, the properties of FRP components and reinforcing materials, the design of concrete components with FRP reinforcement, the design of concrete components prestressed with FRP, the design of components with surface-bonded FRP, the design of fibre-reinforced concrete (FRC)/FRP composite cladding, and seismic design and construction. Normative annexes provide test procedures that are integral to the Standard, while informative annexes describe best current practice.
CSA acknowledges that the development of this Standard was made possible, in part, by the financial support of the following: American Composites Manufacturers Association — FRP Rebar Manufacturers Council, BP Composites Ltd., Fibrewrap Construction Canada Inc., FIRep North America Inc., Hughes Brothers, Inc., ISIS Canada, Public Works Government Services Canada, Pultrall Inc., Schock, Sika Canada, and Vector Construction.
This Standard was prepared by the Technical Committee on Design and Construction of Building Structures with Fibre-Reinforced Polymers, under the jurisdiction of the Strategic Steering Committee on Structures (Design), and has been formally approved by the Technical Committee.
