Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 307: Requirements for Reinforced Concrete Chimneys—Code and Commentary
Likes: 8,311 in 1,373 posts
Given Likes: 94
02-03-2024, 06:28 AM (This post was last modified: 02-03-2024, 06:29 AM by poolmand.)
ACI CODE-307-23: Requirements for Reinforced Concrete Chimneys—Code and Commentary
Author(s)/Editor(s): ACI Committee 307 | Size: 7.33 MB| Format: PDF| Quality: Scanner| Year: 2023| pages: 79 | ISBN: 9781641952286
[Image: 42020159622431311413.jpg]
This Code provides material, design, and detailing requirements for cast-in-place and precast reinforced concrete chimneys. It sets forth minimum loadings for design and contains methods for determining the concrete and reinforcement required to obtain the strength required by the loadings. The methods of analysis apply primarily to circular chimney walls, but guidance is included for applying the general principles to noncircular chimney walls.
across-wind load; construction requirements; earthquake load; flexural strength; load combinations; reinforced concrete; reinforced concrete chimneys; structural design; thermal load; vortex shedding; windload.
  • PinkPant, babakfeyzi, shaker, subin91, kowheng, lisine
  ACI 318.2: Building Code Requirements for Concrete Thin Shells ir_71 7 6,918 12-06-2025, 11:30 AM
  [CivilEA Exclusive] ACI/PCI 319: Structural Precast Concrete —Code Requirements and Commentary poolmand 2 8,020 09-16-2025, 11:03 AM
  ACI 318: Building Code Requirements for Structural Concrete and Commentary robertsas 81 53,435 08-17-2025, 10:45 AM
  [CivilEA Exclusive] ACI 349: Code Requirements for Nuclear Safety Related Concrete Structures andersen3 5 6,316 12-15-2024, 06:33 AM
  [CivilEA Exclusive] ACI 323: Low-Carbon Concrete - Code Requirements and Commentary poolmand 0 2,580 12-15-2024, 05:50 AM
  ACI 440.11: Building Code Requirements for Structural Concrete Reinforced with Glass poolmand 0 2,429 01-08-2024, 08:31 AM
  ACI 437.2: Load Testing of Concrete Structures - Code and Commentary poolmand 1 3,559 11-06-2023, 05:36 AM
