Civil Engineering Association eBooks Codes, Manual & Handbook AWWA AWWA B302: Ammonium Sulfate
Likes: 8,311 in 1,373 posts
Given Likes: 92
01-16-2024, 08:04 AM
AWWA B302-23 Ammonium Sulfate
| Size: 5.42 MB| Format: PDF| Quality: Scanner| Year: 2023 | ISBN: 9781647171322
[Image: 09684236531114472932.jpg]
The purpose of this standard is to provide the minimum requirements for ammonium sulfate, including physical, chemical, sampling, packaging, shipping, and testing requirements.
This standard describes ammonium sulfate for use in the treatment of potable water, wastewater, and reclaimed water. It can be referenced in documents for purchasing and receiving ammonium sulfate and can be used as a guide for testing the physical and chemical properties of ammonium sulfate samples. The stipulations of this standard apply when this document has been referenced and then only to ammonium sulfate used in the treatment of potable water, wastewater, and reclaimed water.
  â€¢ babakfeyzi, PinkPant
  AWWA B406 FERRIC SULFATE poolmand 0 2,985 01-20-2024, 11:51 AM
  AWWA B403 ALUMINUM SULFATE — LIQUID, GROUND, OR LUMP poolmand 0 3,048 01-20-2024, 11:44 AM
  AWWA B402 FERROUS SULFATE poolmand 0 3,086 01-20-2024, 11:42 AM
  AWWA B306: Aqua Ammonia (Liquid Ammonium Hydroxide) poolmand 0 2,958 01-16-2024, 08:15 AM
