Civil Engineering Association eBooks Codes, Manual & Handbook AASHTO AASHTO R69: Standard Practice for Determination of Long-Term Strength for Geosyntheti
Threads: 759
Likes: 8,277 in 1,357 posts
Given Likes: 91
01-15-2024, 09:01 AM
AASHTO R69-20: Standard Practice for Determination of Long-Term Strength for Geosynthetic Reinforcement
| Size: 16.72 MB| Format: PDF| Quality: Scanner| Year: 2020| pages: 47
[Image: 67695945313180366924.jpg]
Through this protocol, the long-term strength and stiffness of geosynthetic reinforcements can be determined. This protocol contains test and evaluation procedures to determine reduction factors for installation damage, creep, and chemical/biological durability, as well as the method to combine these factors to determine the long-term strength. The long-term strength and stiffness values determined from this protocol can be used as input values for geosynthetic structure designs conducted in accordance with the AASHTO LRFD Bridge Design Specifications and related Federal Highway Administration (FHWA) design guidelines. The long-term strength and stiffness values determined from this protocol can also be compared to the required design strength and stiffness values provided in the contract for the geosynthetic structure(s) in question to determine whether the selected product meets the contract requirements. This protocol can be used for product qualification or acceptance (e.g., for inclusion in a Qualified Products List), or for verification to facilitate periodic review of products for which the long-term strength has been previously determined using this standard practice.
This protocol has been developed to address polypropylene (PP), polyethylene (PE or HDPE), and polyester (PET) geosynthetics. See Section 3.1 for definitions of geosynthetic reinforcement and types of geosynthetics addressed in this standard practice. For other geosynthetic polymers [(e.g., polyamide (PA) or polyvinyl alcohol (PVA)], the installation damage and creep protocols provided herein are directly applicable. While the chemical and biological durability procedures and criteria provided herein may also be applicable to other polymers (for example, hydrolysis testing as described in Annex C is likely applicable to PA and PVA geosynthetics), additional investigation will be required to establish a detailed protocol and acceptance criteria for these other polymers. These other polymers may be considered for evaluation using this protocol once modifications to the chemical/biological durability aspects of this protocol have been developed and are agreed on by the approval authority.
This standard was formerly designated as provisional standard PP 66.
  â€¢ babakfeyzi, PinkPant
  AASHTO M259: Standard Specification for Precast Reinforced Concrete Monolithic Box Se poolmand 1 3,626 09-23-2024, 10:15 AM
  AASHTO M351: Standard Specification for Cotton Duck Fabric Bridge Bearings, poolmand 0 3,203 01-15-2024, 08:42 AM
  AASHTO M270M/M270: Standard Specification for Structural Steel for Bridges poolmand 0 3,118 01-15-2024, 08:34 AM
  AASHTO M207M/M207: Standard Specification for Reinforced Concrete Elliptical Culver poolmand 0 2,985 01-08-2024, 05:25 AM
  AASHTO T85: Standard Method of Test for Specific Gravity and Absorption of Coarse poolmand 0 3,202 12-11-2022, 06:01 AM
  AASHTO T84: Standard Method of Test for Specific Gravity and Absorption of Fine A poolmand 0 3,379 12-11-2022, 05:55 AM
  AASHTO - Standard Specifications for Structural Supports for Highway Signs, Luminaire jamildear4u 6 7,758 01-25-2022, 10:57 AM
