Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS D14.7/D14.7M: Recommended Practices for Surfacing and Reconditioning of Industria
Likes: 8,311 in 1,373 posts
Given Likes: 92
09-09-2023, 12:52 PM
AWS D14.7/D14.7M-2005: Recommended Practices for Surfacing and Reconditioning of Industrial Mill Rolls
| Size: 24.6 MB| Format: PDF| Quality: Scanner| Year: 1st Edition, 2005| pages: 68
[Image: 83968639095222494257.jpg]
An industrial mill roll can be defined as any roll or cylindrical body that transports, processes, guides or performs a function in creating a product in the heavy metals, paper, plastic, or lumber industries. These rolls can come in many shapes and sizes (as shown in Figure 1), and include, but are not limited to, table rolls, guide rolls, caster rolls, pinch rolls, leveler rolls, straightener rolls, bridle rolls, and blocker rolls.
This standard provides guidance, based upon experience, for preparing, building up and overlaying by welding, postweld heat treating (PWHT), finish machining, inspecting, and record-keeping of new and reconditioned industrial mill rolls. While mainly used in the primary metal-working industry, industrial mill rolls are also used in other applications. Because common practice predominately employs submerged arc welding (SAW), this document emphasizes SAW. However many of the principles are applicable, with suitable modifications, to gas metal arc welding (GMAW), flux cored arc welding (FCAW), and electroslag cladding.
This standard makes use of both U.S. Customary Units and the International System of Units (SI). The measurements may not be exact equivalents; therefore each system should be used independently of the other without combining in any way. The designation D14.7 uses U.S. Customary Units. The designation D14.7M uses SI Units. The latter are shown in appropriate columns in tables and figures or within brackets [ ]. Detailed dimensions on figures are in inches. A separate tabular form that relates the U.S. Customary Units with SI Units may be used in tables and figures.
Safety and health issues and concerns are beyond the scope of this standard, and therefore are not fully addressed herein. Safety and health information is available from other sources, including, but not limited to, ANSI Z49.1, Safety in Welding, Cutting, and Allied Processes, and applicable federal and state regulations.
Welding symbols shown on drawings should be compatible with those shown in AWS A2.4, Standard Symbols for Welding, Brazing, and Nondestructive Examination. Special conditions or deviations should be fully explained by added notes, details, or definitions.
  â€¢ babakfeyzi, PinkPant, kowheng
  AWS A5.21/A5.21M: Specification for Bare Electrodes and Rods for Surfacing poolmand 1 3,579 05-29-2024, 10:53 AM
  AWS D10.10/D10.10M: Recommended Practices for Local Heating of Welds in Piping and Tu poolmand 0 1,645 09-04-2023, 11:44 AM
  AWS D10.8: Recommended Practices for Welding of Chromium-Molybdenum Steel Piping and poolmand 0 1,889 09-04-2023, 11:40 AM
  AWS D10.6/D10.6M: Recommended Practices for Gas Tungsten Arc Welding of Titanium Pipe poolmand 0 1,543 09-04-2023, 11:35 AM
  AWS C7.2M: Recommended Practices for Laser Beam Welding, Cutting, and Allied Processe poolmand 0 1,632 09-02-2023, 09:39 AM
  AWS C7.1M/C7.1: Recommended Practices for Electron Beam Welding and Allied Processes poolmand 0 1,655 09-02-2023, 09:36 AM
  AWS C6.1: Recommended Practices for Friction Welding poolmand 0 1,515 09-02-2023, 09:20 AM
