Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS D14.5/D14.5M: Specification for Welding of Presses and Press Components
Likes: 8,311 in 1,373 posts
Given Likes: 92
09-09-2023, 12:45 PM
AWS D14.5/D14.5M-2009: Specification for Welding of Presses and Press Components
| Size: 50.8 MB| Format: PDF| Quality: Scanner| Year: 3rd Edition, 2009| pages: 160
[Image: 03263170666190722374.jpg]
The purpose of this specification is to establish minimum acceptable requirements for weld joint design and the fabrication by welding of presses and press components, and is not intended to apply to material feed mechanisms and tooling.
It shall also apply to the modification or repair by welding of new or existing presses or press components.
Its intent is to promote the following:
(1) High-quality construction and repair of presses
(2) Adequate initial and sustained performance of equipment
(3) Personnel and equipment safety
(4) Clear, concise fabrication practices that will be readily understood by the manufacturer, fabricator, buyer, and user
(5) Conservation of human and material resources in both manufacture and employment of equipment
This specification establishes the minimum acceptable practice at the time of its publication. It is not intended to restrict new developments or in any way to inhibit advances in the art of welding.
  â€¢ babakfeyzi, PinkPant, kowheng
  [CivilEA Exclusive] A5.22 / A5.22M: SPECIFICATION FOR STAINLESS STEEL FLUX CORED AND METAL CORED WELDING poolmand 0 2,869 02-03-2025, 06:02 AM
  AWS D17.1/D17.1M: SPECIFICATION FOR FUSION WELDING FOR AEROSPACE APPLICATIONS poolmand 1 3,633 09-24-2024, 07:29 AM
  [CivilEA Exclusive] AWS D14.0/D14.0M: MACHINERY AND EQUIPMENT WELDING SPECIFICATION poolmand 0 3,140 09-24-2024, 07:18 AM
  AWS A5.14/A5.14M: Specification for Nickel and Nickel- Alloy Bare Welding Electrodes poolmand 1 3,492 01-27-2024, 11:18 AM
  AWS J1.3/J1.3M: SPECIFICATION FOR MATERIALS USED IN RESISTANCE WELDING ELECTRODES poolmand 0 3,084 01-22-2024, 12:10 PM
  AWS J1.1M/J1.1: SPECIFICATION FOR RESISTANCE WELDING CONTROLS poolmand 0 3,140 01-22-2024, 12:05 PM
  AWS G1.2M/G1.2: SPECIFICATION FOR STANDARDIZED ULTRASONIC WELDING TEST SPECIMEN FOR T poolmand 0 2,020 01-22-2024, 11:29 AM
