Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS D10.7M/D10.7: Guide for the Gas Shielded ArcWelding of Aluminum and Aluminum Allo
Likes: 8,311 in 1,373 posts
Given Likes: 92
09-04-2023, 11:37 AM
AWS D10.7M/D10.7-2008: Guide for the Gas Shielded ArcWelding of Aluminum and Aluminum Alloy Pipe
| Size: 13.24 MB| Format: PDF| Quality: Scanner| Year: 4th Edition, 2008| pages: 44
[Image: 57618213670737086539.jpg]
This standard provides a summary of recommended industrial practices for welding piping1 fabricated from aluminum alloys. Joint design, welding current, and shielding gas tables are included. This standard makes use of both the International System of Units (SI) and U.S. Customary Units. The measurements may not be exact equivalents; therefore, each system must be used independently of the other without combining in any way. The standard with the designation D10.7M:2000 uses SI Units. The standard designation D10.7:2000 uses U.S. Customary Units. The latter are shown within parenthesis ( ) or in appropriate columns in tables and figures. Pipe sizes are listed as DN (diameter nominal) and NPS (nominal pipe size). The exact pipe diameters are listed in Table 13.
  â€¢ PinkPant, babakfeyzi, kowheng
  AWS D17.3/D17.3M: SPECIFICATION FOR FRICTION STIR WELDING OF ALUMINUM ALLOYS FOR AERO poolmand 0 1,844 01-22-2024, 09:22 AM
  AWS D8.14M: Specification for Automotive Weld Quality - Arc Welding of Aluminum poolmand 0 1,543 09-03-2023, 06:53 AM
  AWS D3.7: Guide for Aluminum Hull Welding poolmand 0 1,649 09-03-2023, 05:11 AM
  AWS D1.2/D1.2M: Structural Welding Code - ALUMINUM poolmand 1 3,946 09-02-2023, 11:43 AM
  AWS C3.7M/C3.7: Specification for Aluminum Brazing poolmand 0 1,958 08-27-2023, 08:51 AM
  AWS A5.3/A5.3M: Specification for Aluminum and Aluminum-Alloy Electrodes for Shielde poolmand 2 2,404 08-26-2023, 06:23 AM
  AWS A5.35/A5.35M: Specification for Covered Electrodes for Underwater Wet Shielded Me poolmand 2 2,395 08-26-2023, 06:14 AM
