Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS D3.9/D3.9M: Specification for the Classification of Weld-Through Paint Primers
Likes: 8,311 in 1,373 posts
Given Likes: 92
09-03-2023, 05:14 AM
AWS D3.9/D3.9M-2019: Specification for the Classification of Weld-Through Paint Primers
| Size: 5.52 MB| Format: PDF| Quality: Scanner| Year: 2nd Edition, 2019| pages: 28
[Image: 60410498964100353106.jpg]
This standard specifies the requirements for classification of weld-through paint primers only. The paint primers are classified based on the maximum coating thickness for successful welding and the welding procedure used during the classification test. This standard provides a system for paint manufacturers to classify the weldability features of weld-through paint primers. This standard is limited to weld-through paint primers only and does not include galvanized or other types of protective coatings.
  β€’ PinkPant, babakfeyzi, kowheng
  AWS D8.14M: Specification for Automotive Weld Quality - Arc Welding of Aluminum poolmand 0 1,543 09-03-2023, 06:53 AM
  AWS D8.10M: Specification for Automotive Weld Qualityβ€”Laser Beam Welding of Steel poolmand 0 1,774 09-03-2023, 06:50 AM
  AWS D8.8M: Specification for Automotive Weld Quality - Arc Welding of Steel poolmand 0 1,763 09-03-2023, 06:46 AM
  AWS D8.2M: Specification for Automotive Weld Quality-Resistance Spot Welding of Alumi poolmand 0 1,464 09-03-2023, 06:43 AM
  AWS D8.1M: Specification for Automotive Weld Quality Resistance Spot Welding of Steel poolmand 0 1,630 09-03-2023, 06:41 AM
