Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS C3.12M/C3.12: Specification for Furnace Soldering
Likes: 8,311 in 1,373 posts
Given Likes: 92
08-27-2023, 09:05 AM
AWS C3.12M/C3.12-2017: Specification for Furnace Soldering
| Size: 4.41 MB| Format: PDF| Quality: Scanner| Year: 1st Edition, 2017| pages: 30
[Image: 32808871125445988424.png]
AWS C3.12M/C3.12, 1st Edition, 2017 - Specification for Furnace Soldering
This specification presents the minimum fabrication and quality requirements for the furnace soldering of materials that include elemental metals, metal alloys, and ceramic base materials that are in geometries that suit the application.
The purpose of this specification is to standardize furnace soldering process requirements that will assure that the solder joints attain the quality level designated by the application. This document establishes the minimum such requirements. It also provides explanations with details to prevent ambiguity within the descriptions. This document assigns responsibility for solder joint quality to the Organization Having Quality Responsibility and permits that organization to modify requirements as necessary. All such modifications shall be in writing. It assigns responsibility for the ultimate quality of the soldered product to a single organization and permits that organization to modify requirements if appropriate to the application. It requires proper documentation of any such modifications.
  â€¢ babakfeyzi, kowheng, PinkPant, Administrator
  AWS C3.11M/C3.11: Specification for Torch Soldering poolmand 1 3,542 05-29-2024, 11:05 AM
  [CivilEA Exclusive] AWS GHSP Guideline for Hand Soldering Practices poolmand 0 1,506 08-27-2023, 09:21 AM
  [CivilEA Exclusive] AWS SHB: Soldering Handbook poolmand 0 1,618 08-27-2023, 09:17 AM
  AWS C3.6M/C3.6: Specification for Furnace Brazing poolmand 0 1,729 08-27-2023, 08:48 AM
  [CivilEA Exclusive] AWS B2.3/B2.3M: SPECIFICATION FOR SOLDERING PROCEDURE AND PERFORMANCE QUALIFICAT poolmand 0 1,573 08-19-2023, 12:01 PM
