Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS A5.35/A5.35M: Specification for Covered Electrodes for Underwater Wet Shielded Me
Likes: 8,311 in 1,373 posts
Given Likes: 92
08-23-2023, 07:25 AM (This post was last modified: 08-26-2023, 06:13 AM by Administrator. Edit Reason: N/A )
AWS A5.35/A5.35M-2015 AMD1: Specification for Covered Electrodes for Underwater Wet Shielded Metal Arc Welding
| Size: 4.07 MB| Format: PDF| Quality: Scanner| Publisher: American Welding Society, Inc. (AWS) | Year: 2015+AMD1| pages: 34
[Image: 21248966418618527881.png]
AWS A5.35/A5.35M, 2015 Edition, 2015 - Specification for Covered Electrodes for Underwater Wet Shielded Metal Arc Welding
This specification prescribes requirements for the classification, based on underwater wet welding test and associated evaluation, of covered electrodes for underwater wet shielded metal arc welding. Requirements for certification of test results are also shown herein. The specification covers ferritic steel, austenitic stainless steel, and nickel filler metals plus any auxiliary coatings applied over the electrode covering. Unless otherwise specified herein, the term β€œmanufacturer” refers to the provider of the finished product (the electrode ready for underwater use). The requirements herein are intended to classify electrodes without consideration for potential base metals to be welded; suitability for specific base metals should be established by the customer during welding procedure qualification testing (see Annex A for further considerations).
This specification does not govern depth of water capability or maximum exposure time for wet welding electrodes classified to this document. However, such information shall be clearly shown as required by the marking requirements of Clause 14.
Safety and health issues and concerns are beyond the scope of this standard and, therefore, are not fully addressed herein. Some safety and health information can be found in informative Annex A. Safety and health information is available from other sources, including, but not limited to, ANSI Z49.1, Safety in Welding, Cutting, and Allied Processes, and applicable federal and state regulations.
  β€’ jcbv, babakfeyzi, PinkPant, kowheng
 whysx
User ID: 2025
Threads: 22
Likes: 22 in 11 posts
Given Likes: 0
08-24-2023, 02:40 AM
Wrong files attached.
  β€’
Given Likes: 92
08-26-2023, 06:14 AM
(08-24-2023, 02:40 AM)whysx Wrote: Wrong files attached.
TNX for report. replaced.
  β€’ PinkPant
  AWS A5.12M/A5.12: Specification for Tungsten and Oxide Dispersed Tungsten Electrodes poolmand 1 3,622 09-24-2024, 07:03 AM
  AWS A5.21/A5.21M: Specification for Bare Electrodes and Rods for Surfacing poolmand 1 3,579 05-29-2024, 10:53 AM
  AWS A5.14/A5.14M: Specification for Nickel and Nickel- Alloy Bare Welding Electrodes poolmand 1 3,492 01-27-2024, 11:18 AM
  AWS J1.3/J1.3M: SPECIFICATION FOR MATERIALS USED IN RESISTANCE WELDING ELECTRODES poolmand 0 3,084 01-22-2024, 12:10 PM
  AWS D3.6M: Underwater Welding Code poolmand 0 1,557 09-03-2023, 04:54 AM
  AWS A5.3/A5.3M: Specification for Aluminum and Aluminum-Alloy Electrodes for Shielde poolmand 2 2,407 08-26-2023, 06:23 AM
  AWS A5.6/A5.6M: Specification for Copper and Copper-Alloy Electrodes for Shielded Met poolmand 2 2,195 08-26-2023, 05:53 AM
