Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS A5.26/A5.26M: Specification for Carbon and Low-Alloy Steel Electrodes for Electro
Likes: 8,311 in 1,373 posts
Given Likes: 92
08-23-2023, 06:46 AM
AWS A5.26/A5.26M-2020: Specification for Carbon and Low-Alloy Steel Electrodes for Electrogas Welding
| Size: 4.7 MB| Format: PDF| Quality: Scanner| Publisher: American Welding Society, Inc. (AWS) | Year: 4th Edition, 2020| pages: 38
[Image: 51360333266587183967.png]
AWS A5.26/A5.26M, 4th Edition, 2020 - Specification for Carbon and Low-Alloy Steel Electrodes for Electrogas Welding
This specification prescribes requirements for the classification of carbon and low-alloy steel electrodes for electrogas welding. It covers solid and tubular (flux cored and metal cored) electrodes, for use either with or without external gas shielding.
This specification makes use of both U.S. Customary Units and the International System of Units (SI). The measurements are not exact equivalents; therefore, each system must be used independently of the other without combining in any way when referring to material properties. The specification designated A5.26 uses U.S. Customary Units. The specification designated A5.26M uses the International System of Units (SI). The latter are shown within brackets [ ] or in appropriate columns in tables and figures. Standard dimensions based on either system may be used for sizing of electrodes, packaging, or both under A5.26 or A5.26M specifications.
Safety and health issues and concerns are beyond the scope of this standard; some safety and health information is provided, but such issues are not fully addressed herein. Some safety and health information can be found in the nonmandatory annex, Clauses A5 and A9.
Safety and Health information is available from the following sources:
American Welding Society:
(1) ANSI Z49.1, Safety in Welding, Cutting, and Allied Processes
(2) AWS Safety and Health Fact Sheets
(3) Other safety and health information on AWS website
Material or Equipment Manufacturers:
(1) Safety Data Sheets supplied by material manufacturers
(2) Operating Manuals supplied by equipment manufacturers
Applicable Regulatory Agencies
Work performed in accordance with this standard may involve the use of materials that have been deemed hazardous, and may involve operations or equipment that may cause injury or death. This standard does not purport to address all safety and health risks that may be encountered. The user of this standard should establish an appropriate safety program to address such risks as well as to meet applicable regulatory requirements. ANSI Z49.1 should be considered when developing the safety program.
  β€’ babakfeyzi, PinkPant, kowheng
  AWS A5.12M/A5.12: Specification for Tungsten and Oxide Dispersed Tungsten Electrodes poolmand 1 3,621 09-24-2024, 07:03 AM
  AWS A5.21/A5.21M: Specification for Bare Electrodes and Rods for Surfacing poolmand 1 3,579 05-29-2024, 10:53 AM
  AWS A5.14/A5.14M: Specification for Nickel and Nickel- Alloy Bare Welding Electrodes poolmand 1 3,492 01-27-2024, 11:18 AM
  AWS J1.3/J1.3M: SPECIFICATION FOR MATERIALS USED IN RESISTANCE WELDING ELECTRODES poolmand 0 3,084 01-22-2024, 12:10 PM
  AWS D18.1/D18.1M: SPECIFICATION FOR WELDING OF AUSTENITIC STAINLESS STEEL TUBE AND P poolmand 0 2,678 01-22-2024, 09:43 AM
  AWS D8.10M: Specification for Automotive Weld Qualityβ€”Laser Beam Welding of Steel poolmand 0 1,775 09-03-2023, 06:50 AM
  AWS D8.8M: Specification for Automotive Weld Quality - Arc Welding of Steel poolmand 0 1,765 09-03-2023, 06:46 AM
