Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS D1.6/D1.6M: Structural Welding Code - Stainless Steel
Likes: 8,311 in 1,373 posts
Given Likes: 92
08-19-2023, 06:20 AM (This post was last modified: 09-02-2023, 12:00 PM by Administrator.)
AWS D1.6/D1.6M-2017: Stainless Steel
| Size: 8.88 MB| Format: PDF| Quality: Original preprint| Year: 2017| pages: 340
[Image: 82692325888195313523.jpg]
AWS D1.6/D1.6M-2017: Structural Welding Code – Stainless Steel contains welding recommendations for the fabrication, assembly, and erection of welded structures and weldments subject to design stress in which at least one of the materials being joined is stainless steel. It is for use with base metals with a minimum thickness of 1/16 in (1.5 mm) or 16 gage, in conjunction with any complementary code or specification for the design or construction of stainless steel structures and weldments. In addition to background information and terms relevant to those involved with stainless steel fabrication, the AWS D1.6-2017 code includes a clause that covers guidance on the design of welded connections. Other clauses in the standard focus on exempting a Welding Procedure Specification (WPS) from qualification by testing, qualifying WPSs and welding personnel, the fabrication, assembly, and erection of welded stainless steel structures, inspection and acceptance criteria, and stud welding.
Read more at the ANSI Blog: AWS D1.6-2017 Changes: Welding Code – Stainless Steel https://blog.ansi.org/?p=6905
  β€’ PinkPant, jcbv, cheosmith, blaze, babakfeyzi, kowheng
Given Likes: 92
09-02-2023, 11:57 AM
AWS D1.6/D1.6M-2017+AMD+Errata: Structural Welding Codeβ€” Stainless Steel
Includes all amendments and changes through Amendment 1, 2021
| Size: 9.13 MB| Format: PDF| Year: 3rd Edition, 2017| pages: 346
This code contains welding requirements for the fabrication, assembly, and erection of welded structures and weldments subject to design stress where at least one of the materials being joined is stainless steel. The code is intended to be used for base metals with a minimum thickness of 1/16 in [1.5 mm] or 16 gage. It shall be used in conjunction with any complementary code or specification for the design or construction of stainless steel structures and weldments. When this code is stipulated in contract documents, conformance with all provisions of the code shall be required, except for those provisions that the Engineer (see 1.5.1) or contract documents specifically modify or exempt.
The following is a summary of the code clauses:
(1) General Requirements. This clause contains basic information on the scope and limitations of the code, key definitions, and the major responsibilities of the parties involved with stainless steel fabrication.
(2) Normative References. This clause contains a list of reference documents that assist the user in implementation of this code or are required for implementation.
(3) Terms and Definitions. This clause contains terms and definitions as they relate to this code.
(4) Design of Welded Connections. This clause contains requirements for the design of welded connections.
(5) Prequalification. This clause contains the requirements for exempting a Welding Procedure Specification (WPS) from qualification by testing.
(6) Qualification. This clause contains the requirements for qualification of WPSs and welding personnel (welders and welding operators) by testing, including the tests required and the ranges qualified.
(7) Fabrication. This clause contains welding requirements for fabrication, assembly, and erection of welded stainless steel structures governed by this code, including the requirements for base metals, welding consumables, welding technique, weld details, material preparation and assembly, workmanship, weld repair, and other requirements.
(8) Inspection. This clause contains the requirements for the Inspector’s qualifications and responsibilities, acceptance criteria for discontinuities, and procedures for nondestructive testing (NDT).
(9) Stud Welding. This clause contains the requirements for welding of studs to structures where at least one of the materials being joined is stainless steel.
  β€’ babakfeyzi, jcbv, PinkPant, subin91, kowheng
  [CivilEA Exclusive] A5.22 / A5.22M: SPECIFICATION FOR STAINLESS STEEL FLUX CORED AND METAL CORED WELDING poolmand 0 2,868 02-03-2025, 06:02 AM
  [CivilEA Exclusive] D10.4M-D10.4: GUIDE FOR WELDING AUSTENITIC STAINLESS STEEL PIPING AND TUBING poolmand 0 3,013 02-03-2025, 05:56 AM
  AWS D18.2 GUIDE TO WELD DISCOLORATION LEVELS ON INSIDE OF AUSTENITIC STAINLESS STEEL poolmand 0 2,773 01-22-2024, 09:52 AM
  AWS D18.1/D18.1M: SPECIFICATION FOR WELDING OF AUSTENITIC STAINLESS STEEL TUBE AND P poolmand 0 2,676 01-22-2024, 09:43 AM
  AWS D9.1/D9.1M: SHEET METAL WELDING CODE poolmand 0 2,044 09-04-2023, 12:08 PM
  AWS D10.18M/D10.18: Guide for Welding Ferritic/Austenitic Duplex Stainless Steel Pipi poolmand 0 1,737 09-04-2023, 12:00 PM
  AWS D10.12M/D10.12: Guide for Welding Mild Steel Pipe poolmand 0 2,056 09-04-2023, 11:49 AM
