Civil Engineering Association Various Free Discussion Lavteam site is down?
 JIM1975
Greece
User ID: 268
Threads: 9
Likes: 228 in 24 posts
Given Likes: 10
04-19-2023, 07:07 AM (This post was last modified: 04-19-2023, 08:25 PM by Dell_Brett.)
Dear friends,
Does anyone knows what is going on and lavteam is down for the last week or so..
Thanks.
MODERATPR NOTE:
No notice!
[-] The following 9 users Like JIM1975's post:9 users Like JIM1975's post
  β€’ vvvv, sabooryan, ascetic19, Pitagora, jtbullion2, fashion, daywalker, dr.dife85, designervn
 tomtumx
User ID: 2851
Threads: 18
Likes: 725 in 124 posts
Given Likes: 772
04-20-2023, 04:38 AM (This post was last modified: 04-20-2023, 11:12 PM by Dell_Brett.)
Adding to c:\windows\system32\drivers\etc\hosts
the following 3 lines:
works for me.Β  Could someone explain what's happening?
[-] The following 4 users Like tomtumx's post:4 users Like tomtumx's post
  β€’ agelos100, jorgeramos, edersongrima33, designervn
 jorgeramos
User ID: 3729
Threads: 20
Likes: 229 in 29 posts
Given Likes: 344
04-20-2023, 11:53 AM (This post was last modified: 04-20-2023, 11:12 PM by Dell_Brett.)
(04-20-2023, 04:38 AM)tomtumx Wrote: Adding to c:\windows\system32\drivers\etc\hosts
Using this process it is possible to open the page. However, if you are interested in downloading any particular software, it is not possible to access the respective link, with the same following error: lavteam.org’s server IP address could not be found.
[-] The following 1 user Likes jorgeramos's post:1 user Likes jorgeramos's post
  β€’ designervn
 tomtumx
User ID: 2851
Threads: 18
Given Likes: 772
04-21-2023, 01:17 AM (This post was last modified: 04-21-2023, 03:25 AM by Dell_Brett.)
Add another line then:
[-] The following 5 users Like tomtumx's post:5 users Like tomtumx's post
  β€’ Arigato, Batman07, jorgeramos, rigid_joint, designervn
 hmwere
Uganda
User ID: 17377
Threads: 93
Likes: 421 in 152 posts
Given Likes: 1475
04-21-2023, 10:13 AM
Dear tomtumx,
Please share a screenshot on how these lines are added. Do we edit "hosts" in notepad?
[-] The following 1 user Likes hmwere's post:1 user Likes hmwere's post
  β€’ designervn
 jorgeramos
User ID: 3729
Threads: 20
Given Likes: 344
04-21-2023, 11:43 AM
(04-21-2023, 01:17 AM)tomtumx Wrote: Add another line then:
Thanks for the first line suggestion. Solve the question I posed in post #3
[-] The following 2 users Like jorgeramos's post:2 users Like jorgeramos's post
  β€’ rami1976, designervn
 jorgeramos
User ID: 3729
Threads: 20
Given Likes: 344
04-21-2023, 11:45 AM
(04-21-2023, 10:13 AM)hmwere Wrote: Dear tomtumx,
Yes, you can edit the file with the notepad application and save with administrator permissions
  β€’ designervn
 hmwere
Uganda
User ID: 17377
Threads: 93
Given Likes: 1475
04-21-2023, 12:09 PM (This post was last modified: 04-21-2023, 07:16 PM by Dell_Brett.)
Please share a screen shot on how to add the lines under notepad. We are not computer literate to that extent.
Lav retuns!
ItΒ΄s online just now!
  β€’ designervn
 rigid_joint
Senior Member
Jamaica
User ID: 6110
Threads: 13
Likes: 333 in 122 posts
Given Likes: 244
04-21-2023, 08:11 PM (This post was last modified: 04-21-2023, 08:33 PM by Dell_Brett.)
Dear all, tomtumx suggestion works fine.
You find the file "c:\windows\system32\drivers\etc\hosts" and open it with notepad+ but with administration rights.
You simply paste at the end the 4 suggested lines, you save it and close it and you are finally there.
MODERATOR NOTE:
ItΒ΄s not necessary!
LAV is back!
Tomorrow all posts referring to this topic will be deleted.
[-] The following 2 users Like rigid_joint's post:2 users Like rigid_joint's post
  β€’ hmwere, designervn
  Lavteam site is down? jorgeramos 8 14,369 05-17-2025, 01:47 PM
Last Post: jorgeramos
  [PROBLEM] Is lavteam.net down? netsonicyxf 6 13,379 11-24-2015, 07:01 PM
  lavteam exclusive Arigato 4 13,206 07-30-2014, 08:32 AM
Last Post: Administrator
  LAVTeam mig21 2 8,818 06-02-2010, 11:14 AM
Last Post: robertsas
