Civil Engineering Association Software Software Product Csi Products ETABS CSI ETABS V21
CSI ETABS V21
 Arigato
Ireland
User ID: 740
Threads: 37
Likes: 893 in 88 posts
Given Likes: 277
04-09-2023, 05:24 AM (This post was last modified: 10-02-2023, 10:57 AM by Administrator.)
CSi ETABS v21.0.0 - (NO MEDICINE)
[Image: 13284336976246706973.jpg]
Related Link:
Abstract:
THE INDUSTRY STANDARD FOR BUILDING MODELING, ANALYSIS AND DESIGN
[Image: comments.png]
👉 SETUP files only, no medicine.
[-] The following 11 users Like Arigato's post:11 users Like Arigato's post
  â€¢ zrilek, TAFATNEB, Dell_Brett, PinkPant, simanta, benny, Batman07, jcbv, jokerâ„¢, narendra, zego2000
 Arigato
Ireland
User ID: 740
Threads: 37
Given Likes: 277
04-10-2023, 10:45 PM (This post was last modified: 04-12-2023, 08:37 AM by Dell_Brett.)
CSi ETABS v21.0.0 - MEDICINE ONLY
[-] The following 12 users Like Arigato's post:12 users Like Arigato's post
  â€¢ benny, PinkPant, Batman07, zrilek, rami1976, jcbv, TAFATNEB, simanta, babakfeyzi, pcworks200, Dell_Brett, narendra
Threads: 830
04-13-2023, 09:08 AM (This post was last modified: 05-02-2023, 05:49 AM by rami1976.)
CSI ETABS Ultimate 21.0.0 Build 3143 (x64)
[Image: 45279530341860686162.jpg]
he innovative and revolutionary new ETABS is the ultimate integrated software package for the structural analysis and design of buildings. Incorporating 40 years of continuous research and development, this latest ETABS offers unmatched 3D object based modeling and visualization tools, blazingly fast linear and nonlinear analytical power, sophisticated and comprehensive design capabilities for a wide-range of materials, and insightful graphic displays, reports, and schematic drawings that allow users to quickly and easily decipher and understand analysis and design results.
From the start of design conception through the production of schematic drawings, ETABS integrates every aspect of the engineering design process. Creation of models has never been easier - intuitive drawing commands allow for the rapid generation of floor and elevation framing. CAD drawings can be converted directly into ETABS models or used as templates onto which ETABS objects may be overlaid. The state-of-the-art SAPFire 64-bit solver allows extremely large and complex models to be rapidly analyzed, and supports nonlinear modeling techniques such as construction sequencing and time effects (e.g., creep and shrinkage).
Design of steel and concrete frames (with automated optimization), composite beams, composite columns, steel joists, and concrete and masonry shear walls is included, as is the capacity check for steel connections and base plates. Models may be realistically rendered, and all results can be shown directly on the structure. Comprehensive and customizable reports are available for all analysis and design output, and schematic construction drawings of framing plans, schedules, details, and cross-sections may be generated for concrete and steel structures.
ETABS provides an unequaled suite of tools for structural engineers designing buildings, whether they are working on one-story industrial structures or the tallest commercial high-rises. Immensely capable, yet easy-to-use, has been the hallmark of ETABS since its introduction decades ago, and this latest release continues that tradition by providing engineers with the technologically-advanced, yet intuitive, software they require to be their most productive.
Modeling
Added codes for creep, shrinkage, and stiffness aging: Eurocode 2-2004, Australian Standard 3600-2009, New Zealand Standard 3101-2006 and GL 2000 models.
Analysis
Creep & Shrinkage
Creep and shrinkage behavior now includes the effect of rebar to reduce axial shortening of columns and walls.
Modal Damping
Modal damping option for linear and nonlinear direct-integration time-history analysis, providing more realistic and conservative results.
Results Display & Output
Slab cracked-width display based on Eurocode 2-2004.
  â€¢ jcbv, rami1976, PinkPant, zrilek, cace-01, Dell_Brett, mowafi3m, blaze, narendra
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,317 in 676 posts
Given Likes: 1667
04-26-2023, 02:33 PM
Dear friend @TAFATNEB
could you Plz to re-upload it on Mediafire or similar
the first link is very slow and stops after a short time
the second link isn't working in our country
thanks in advance
  â€¢
 kirankumarklk
User ID: 29935
Threads: 76
Likes: 960 in 135 posts
Given Likes: 280
05-18-2023, 08:31 AM
ETABS v21.0.1
[-] The following 12 users Like kirankumarklk's post:12 users Like kirankumarklk's post
  â€¢ Dell_Brett, zrilek, temp1366, Arigato, benny, Batman07, simanta, jcbv, narendra, ascetic19, hzaheer, mowafi3m
 Arigato
Ireland
User ID: 740
Threads: 37
Given Likes: 277
05-26-2023, 06:05 AM
👉 ETABS v21.0.1 vaccine only
[-] The following 10 users Like Arigato's post:10 users Like Arigato's post
  â€¢ jcbv, Dell_Brett, babakfeyzi, rami1976, PinkPant, zrilek, narendra, ascetic19, blaze, mowafi3m
 kirankumarklk
User ID: 29935
Threads: 76
Given Likes: 280
08-19-2023, 01:08 PM
ETABS v21.1.0
[-] The following 8 users Like kirankumarklk's post:8 users Like kirankumarklk's post
  â€¢ zrilek, Dell_Brett, blaze, Batman07, ascetic19, kowheng, mowafi3m, narendra
Threads: 750
Likes: 8,270 in 1,355 posts
Given Likes: 88
10-02-2023, 06:48 AM
CSI ETABS v21.1.0 Build 3261 x64
For nearly 30 years, ETABS has been recognized as the industry standard for Building Analysis and Design Software. Today, continuing in the same tradition, ETABS has evolved into a completely integrated building analysis and design environment. The system built around a physical object based graphical user interface, powered by targeted new special purpose algorithms for analysis and design, with interfaces for drafting and manufacturing, is redefining standards of integration, productivity and technical innovation.
The integrated model can include moment resisting frames, braced frames, staggered truss systems, frames with reduced beam sections or side plates, rigid and flexible floors, sloped roofs, ramps and parking structures, mezzanine floors, multiple tower buildings and stepped diaphragm systems with complex concrete, composite or steel joist floor framing systems. solutions to complex problems such as panel zone deformations, diaphragm shear stresses, and construction sequence loading are now at your fingertips.
ETABS is the solution, whether you are designing a simple 2D frame or performing a dynamic analysis of a complex high-rise that utilizes non-linear dampers for inter-story drift control.
The innovative and revolutionary new ETABS is the ultimate integrated software package for the structural analysis and design of buildings. Incorporating 40 years of continuous research and development, this latest ETABS offers unmatched 3D object based modeling and visualization tools, blazingly fast linear and nonlinear analytical power, sophisticated and comprehensive design capabilities for a wide-range of materials, and insightful graphic displays, reports, and schematic drawings that allow users to quickly and easily decipher and understand analysis and design results.
[Image: tips.png]
[-] The following 8 users Like poolmand's post:8 users Like poolmand's post
  â€¢ PinkPant, zrilek, Dell_Brett, jcbv, rami1976, zego2000, mowafi3m, lissics
 temp1366
Senior Member
User ID: 85519
Threads: 80
Likes: 1,544 in 165 posts
Given Likes: 741
12-01-2023, 02:00 PM (This post was last modified: 12-01-2023, 02:01 PM by temp1366.)
ETABS V21.2.0
Changes:
Release Note:
[-] The following 8 users Like temp1366's post:8 users Like temp1366's post
  â€¢ rami1976, Dell_Brett, Administrator , zrilek, jcbv, kowheng, TAFATNEB, mowafi3m
