Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 309.5: Compaction of Roller-Compacted Concrete - Report
Likes: 8,311 in 1,373 posts
Given Likes: 94
12-11-2022, 06:20 AM (This post was last modified: 05-02-2023, 11:32 AM by Administrator.)
ACI PRC-309.5-22: Compaction of Roller-Compacted Concrete - Report
Author(s)/Editor(s): ACI Committee 309 | Size: 3.44 MB| Format: PDF| Quality: Original preprint| Year: 2022| pages: 29 | ISBN: 9781641951821
Roller-compacted concrete (RCC) is an accepted and economical method for the construction of dams and pavements. Achieving adequate compaction is essential to the development of the desired properties in the hardened material. The compaction depends on many variables, including the strength of the subbase, materials used in RCC, mixture design proportions, mixing and transporting methods, discharge and spreading practices, compaction equipment and procedures, and lift thickness. The best performance characteristics are obtained when the concrete is reasonably free of segregation; well-bonded at construction joints; and compacted at, or close to, maximum density.
This report summarizes experience in compaction of RCC in various applications and offers guidance in the selection of equipment and procedures for compaction, as well as for quality control of the work. Compaction equipment and procedures should be appropriate for the work. In dam or massive concrete applications, large, self-propelled, smooth, steel-drum vibratory rollers are most commonly used. The frequency and amplitude of the roller should be suited to the mixture and lift thickness required for the work. Other roller parameters, such as static mass, number of drums, diameter, ratio of frame and drum mass, speed, and drum drive influence the rate and effectiveness of the compaction equipment. Smaller equipment, and possibly thinner compacted lifts, are required for areas where access is limited.
Pavements are generally placed with paving machines that produce a smooth surface and some initial compacted density. Final density is obtained with vibratory rollers. Rubber-tired rollers can also be used where surface tearing and cracks would occur from steel-drum rolling. The rubber-tired rollers close fissures and tighten the surface.
Inspection during placement and compaction is also essential to ensure the concrete is free of segregation before compaction and receives adequate coverage by the compaction equipment. Testing is then performed on the compacted concrete on a regular basis to confirm that satisfactory density is consistently achieved. Corrective action should be taken whenever unsatisfactory results are obtained. Roller-compacted concrete offers a rapid and economical method of construction where compaction practices and equipment are a major consideration in both design and construction.
compaction; consolidation; dams; pavements; roller-compacted concrete
  â€¢ PinkPant, blaze, cace-01, Dell_Brett, babakfeyzi, subin91, milova, kowheng, malc
  [CivilEA Exclusive] ACI 228.1: Report on Methods for Estimating In-Place Concrete Strengt poolmand 0 1,619 12-14-2024, 01:23 PM
  [CivilEA Exclusive] ACI 334.3: Construction of Concrete Shells Using Inflatable Forms - Report poolmand 0 1,497 12-14-2024, 01:04 PM
  [CivilEA Exclusive] ACI 327.1: In-Place Density Testing of Freshly Placed Roller-Compacted Concrete by Nu poolmand 0 1,599 10-31-2023, 07:59 AM
  ACI 370: Report for the Design of Concrete Structures for Blast Effects er.shyams 1 2,825 05-09-2023, 09:25 AM
  ACI 445.1: Report on Torsion in Structural Concrete Mohammad6299 3 3,394 05-08-2023, 07:15 AM
  ACI 207.5: Report on Roller-Compacted Mass Concrete Mohammad6299 1 2,403 05-07-2023, 10:06 AM
  ACI 325.10: Report on Roller-Compacted Concrete Pavements Mohammad6299 1 2,436 05-07-2023, 07:09 AM
