Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 533.5: Guide for Precast Concrete Tunnel Segments
Likes: 8,311 in 1,373 posts
Given Likes: 94
10-10-2022, 06:59 AM (This post was last modified: 05-02-2023, 12:43 PM by Administrator.)
ACI PRC-533.5-20: Guide for Precast Concrete Tunnel Segments
| Format: PDF| Quality: Original preprint| Publisher: ACI Committee 533| Year: 5/7/2020| pages: 84 | ISBN: 9781641950978
[Image: 17785438086085056427.jpg]
Categories: Design, Durability, Joints, Precast Concrete
The worldwide trend in construction is toward mechanization and automation. This trend has led to continued rapid progress of mechanized tunneling. Advantages over conventional tunnel construction methods include, but are not limited to, occupational health and safety, faster advance rates, and reducing construction labor requirements. Mechanized tunneling in soft ground using tunnel boring machines is often associated with installing precast concrete segmental lining. However, very little industry-wide guidance has been provided by practice and code organizations. This document provides guidelines for precast concrete tunnel segments, including the most recent developments and practical experience, in addition to information on all aspects of design and construction. These guidelines are based on the knowledge and the experience gained on numerous precast tunnel projects in the United States, and available national and international guidelines often used as industry references.
design; durability; fiber; gasket; joint; lining; precast; segment; tolerance; tunnel.
[-] The following 13 users Like poolmand's post:13 users Like poolmand's post
  β€’ blaze, Administrator , subin91, babakfeyzi, Dell_Brett, zrilek, PinkPant, cace-01, rendel_Β©, Wijono, kowheng, milova, malc
  [CivilEA Exclusive] ACI 548.17: Circular Precast Polymer-Concrete Manholes poolmand 0 908 12-06-2025, 10:50 AM
  [CivilEA Exclusive] ACI/PCI 319: Structural Precast Concrete β€”Code Requirements and Commentary poolmand 2 8,020 09-16-2025, 11:03 AM
