Civil Engineering Association eBooks Codes, Manual & Handbook NFPA 70: National Electrical Code 2020
Likes: 8,311 in 1,373 posts
Given Likes: 94
09-06-2021, 09:07 AM (This post was last modified: 09-06-2021, 09:12 AM by poolmand.)
Author(s)/Editor(s): (NFPA) National Fire Protection Association | Size: 270 MB| Format: PDF| Quality: Original preprint| Publisher: Delmar Cengage Learning| Year: September 18, 2019 | ISBN: 1455922978
[Image: 15350764840119884753.png]
Prepare for the electrical challenges of tomorrow, today, with NFPA 70, National Electrical Code (NEC), 2020 edition.
The world never stops changing, so it's crucial to keep learning how to keep it safe. Incorporated by reference in all 50 states and used across the globe, NFPA 70®, National Electrical Code® (NEC®), is the benchmark standard for electrical safety in residential, commercial, and industrial settings.
NFPA 70, NEC, was first published in 1897 and is continually put through a rigorous review process to keep it up to date with the most current industry practices, emerging trends, and the development and introduction of new technologies. The new NEC provides the latest requirements for safer and more effective electrical design, installation, and inspection, including provisions for wiring, overcurrent protection, grounding, and equipment.
Get up-to-code and prepared for the safety challenges of new sources of electrical power with the NEC, 2020 edition.
The revised and expanded NFPA 70, National Electrical Code, features state-of-the-art information for safe electrical practices for public and private buildings, homes and structures, outdoor yards and lots, utility equipment, installations that connect to the power grid, and consumer-owned power generation systems and equipment.
Content has been added, edited, and reorganized to address safety for workers, energy systems and electric vehicles, limited energy, and communication systems.
Impactful changes include:
New requirements for exterior emergency disconnects of one- and two-family dwellings for improved electrical safety for emergency responders
Revisions to service disconnect rules to help protect electrical workers from arc flash hazards
Adapted and adjusted requirements for installation practices of new technologies to meet the evolving demand of power over Ethernet
Updates to modernize tables currently in use for calculations to reflect improvements in energy efficiency and align with evolving codes
Revised requirements for ground-fault protection within marinas and boatyards
Introduction of guidelines for the safe use of electric vehicles (electric vehicle power export equipment) as a backup or emergency power source for a building or a home
Reorganization of Article 310, including new user-friendly numbering for important ampacity tables, and new definition for cable bundle in Article 725
Relocation of surge protection device requirements to new Article 242
Revisions to alternative energy systems and electric vehicle requirements to clarify what portions of the PV system are covered by the requirements of Article 690 and the line side and load side connections of interconnected power supply sources, and to clearly distinguish energy storage systems from storage battery systems
Reorganization of Article 800 to provide a general set of requirements to apply throughout the Chapter 8 articles
Revisions to requirements for communications cables that are also carrying power to communication devices and revisions to the current limit for cables carrying power and data
The NEC, 2020 edition, introduces significant new requirements for:
The residential installation of receptacle outlets serving island and peninsular countertops and for surge protection of services supplying dwelling units
Working space for “housekeeping pads” for electrical equipment, the installation of wiring methods in exit enclosures, sizing supply and load conductors used with adjustable-speed drive systems, and AFCI protection of branch circuits in patient sleeping areas in care facilities
Calculating the load of electric vehicle supply equipment with variable current settings
Worker safety in identifying the source of power for disconnecting means and for egress from spaces containing large electrical equipment
Grounding of disconnecting means installed on the supply-side of service disconnecting means
Cables installed exposed on ceiling surfaces and sidewalls
Special occupancies, special equipment, and special conditions, including installation of splash pads, the use of “Type P” cables in hazardous classified locations, and the reinspection of swimming pools and other bodies of water
Help protect life and property with the most relevant electrical requirements.
Get the cutting edge information you need to identify and overcome the latest hazards and complexities in electrical work. Order your copy of NFPA 70®, National Electrical Code, 2020 edition, today.
Interested in other editions of the NEC? Use the drop down menu above to select the edition year you need.
[-] The following 11 users Like poolmand's post:11 users Like poolmand's post
  • Administrator , cace-01, Umer.Aleem, shaker, PinkPant, kowheng, blaze, Dell_Brett, mohamz, oanm2000, DonH
  NFPA 5000, Building Construction and Safety Code poolmand 1 2,395 01-03-2022, 01:01 PM
  National Fire Code (NFPA) jamildear4u 2 5,275 02-14-2021, 11:00 AM
Last Post: monter
  National Building Code of India 2005 (Loads forces & Effects) i_kabir 1 2,940 01-15-2016, 08:26 PM
  NFPA 5000 Building Construction and Safety Code 2009 Edition ir_71 1 2,593 09-10-2012, 06:54 PM
Last Post: mahyarov
  Code for Design of Steel Structure – GB 50017-2003-National Standard of China miquan 1 3,094 04-30-2012, 12:00 PM
  NATIONAL STRUCTURAL CODE OF THE PHILIPPINES 2010 EDITION lambert 0 3,927 03-25-2012, 07:30 PM
Last Post: lambert
  NFPA® 30 Flammable and Combustible Liquids Code 2012 Edition ir_71 0 2,485 02-13-2012, 06:49 AM
