Civil Engineering Association eBooks Water & Hydraulic Engineering Basic Hydraulics - 1st Edition
 febo927
User ID: 23688
Threads: 105
Likes: 4,179 in 339 posts
Given Likes: 1279
09-14-2018, 01:03 PM
Author(s)/Editor(s): P D Smith | Size: 2 MB | Format: PDF | Quality: Scanner | Publisher: Butterworth-Heinemann | Year: 1982 | pages: 168 | ISBN: 0-408-01112-2
[Image: 18261766598704177520.jpg]
BASIC Hydraulics aims to help students both to become proficient in the BASIC programming language by actually using the language in an important field of engineering and to use computing as a means of mastering the subject of hydraulics. The book begins with a summary of the technique of computing in BASIC together with comments and listing of the main commands and statements. Subsequent chapters introduce the fundamental concepts and appropriate governing equations. Topics covered include principles of fluid mechanics; flow in pipes, pipe networks and open channels; hydraulic machinery; and seepage and groundwater flow. Each chapter provides a series of worked examples consisting primarily of an introduction in which the general topic or specific problem to be considered is presented. A program capable of solving the problem is then given, together with examples of the output, sometimes for several different sets of conditions. Finally, in a section headed Program Notes the way the program is constructed and operates is explained, and the engineering lessons to be learned from the program output are indicated. Each chapter also concludes with a set of problems for the student to attempt. This book is mainly intended for the first- and second-year undergraduate student of civil engineering who will be concerned with the application of fundamental fluid mechanics theory to civil engineering problems.
[-] The following 15 users Like febo927's post:15 users Like febo927's post
  â€¢ blaze, zrilek, Nita1391, malc, Andrew seah, PinkPant, gulilero, pedzaquino, Dell_Brett, cace-01, oanm2000, cristi, kowheng, spat, Raktim
  Hydraulics and Pneumatics, Second Edition david-smith 0 1,512 04-26-2012, 01:48 PM
Last Post: david-smith
