Civil Engineering Association eBooks Structural Books Analysis & Design Structural Design from First Principles
 cace-01
User ID: 15651
Threads: 433
Likes: 10,522 in 867 posts
Given Likes: 7468
04-05-2018, 01:26 PM
Author(s)/Editor(s): Michael Byfield | Size: 12 MB | Format: PDF | Quality: Unspecified | Publisher: CRC Press | Year: 2018 | pages: 335 | ISBN: 9781498741231, 978-1-1385-0349-6, 978-1-4987-4121-7, 141-157-125-8, 9781315116914, 131511691X, 1498741231, 9781498741255, 1498741258
[Image: 60311353744905552292.jpg]
This enlightening textbook for undergraduates on civil engineering degree courses explains structural design from its mechanical principles, showing the speed and simplicity of effective design from first principles.
This text presents good approximate solutions to complex design problems, such as "Wembley-Arch" type structures, the design of thin-walled structures, and long-span box girder bridges. Other more code-based textbooks concentrate on relatively simple member design, and avoid some of the most interesting design problems because code compliant solutions are complex. Yet these problems can be addressed by relatively manageable techniques. The methods outlined here enable quick, early stage, "ball-park" design solutions to be considered, and are also useful for checking finite element analysis solutions to complex problems.
The conventions used in the book are in accordance with the Eurocodes, especially where they provide convenient solutions that can be easily understood by students. Many of the topics, such as composite beam design, are straight applications of Eurocodes, but with the underlying theory fully explained.
The techniques are illustrated through a series of worked examples which develop in complexity, with the more advanced questions forming extended exam type questions. A comprehensive range of fully worked tutorial questions are provided at the end of each section for students to practice in preparation for closed book exams.
[-] The following 24 users Like cace-01's post:24 users Like cace-01's post
  â€¢ jcbv, mgdario, carolinandra, caifan, oanm2000, cheosmith, milova, emmi, simanta, xnr09, vvvv, munycamsec, blaze, zrilek, Andrew seah, PinkPant, ska51, BLESSED DOVE, monter, Dell_Brett, gulilero, karthikeyans3d, konstobo, levanduy
  Principles of Structural Analysis: Static and Dynamic Loads carolinandra 1 4,142 01-02-2022, 03:32 AM
Last Post: Veggeta
  Principles of Structural Design: Wood, Steel, and Concrete, Second Edition cace-01 4 11,890 11-24-2019, 01:32 PM
Last Post: carolinandra
  Structural Fire Loads: Theory and Principles TAFATNEB 1 5,068 12-27-2016, 12:56 PM
Last Post: gulilero
  Structural Analysis: Principles, Methods and Modelling cace-01 2 7,276 10-29-2015, 03:38 PM
Last Post: ibg0203
  Principles of Structural Design abudabeeja 7 15,313 09-02-2015, 03:44 PM
Last Post: ibg0203
  Principles of Structural Stability Theory SR71 2 8,090 12-13-2014, 08:47 PM
  Principles of Structural Stability amindoxiti 0 3,770 09-04-2014, 02:39 AM
