Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general The Design of temporary Excavation Support to EC7
 gianniorlati
Senior Underground Works Engineer
Italy
User ID: 46169
Threads: 64
Likes: 1,673 in 128 posts
Given Likes: 429
09-30-2017, 05:39 AM (This post was last modified: 09-30-2017, 01:21 PM by oanm2000. Edit Reason: N/A )
The design of temporary excavation support to Eurocode 7
  • Author(s): Paul David Markham
  • Published By: Geotechnical Engineering Volume 165 Issue GE1, ICE Publishing
  • Published Year: 2011
  • DOI: 10.1680/geng.2012.165.1.3
  • Size: 0.426 MB
  • Quality: Original Preprint
  • Abstract: This paper examines how Eurocode 7 relates to the design of temporary excavation support. It is shown that total stress design and the net available passive resistance method described in Ciria Report 104 can produce inconsistent results, which must be carefully checked for sensitivity to the soil parameter values used. Many temporary excavations are designed using moderately conservative soil parameter values and a limit equilibrium method of analysis with a lumped factor of safety of 1.5. It is concluded that design in accordance with Eurocode 7 produces higher propping forces than design using this approach, but that Eurocode 7 produces propping forces over 60% lower than design in accordance with Ciria Report C580.
[-] The following 27 users Like gianniorlati's post:27 users Like gianniorlati's post
  â€¢ PinkPant, blaze, temp1366, Andrew seah, rezart, oanm2000, gulilero, Ivan_1980, zrilek, caifan, cace-01, subin91, dizz, hapsea, Aviator, Dell_Brett, K.Lee, Trishu999, vvvv, Evandrojr, lasalleguy, monter, Aransam, uetian17, tuanpecc1, nhim4mat2006, mohamz
 tuanpecc1
Vietnam
User ID: 16595
Threads: 62
Likes: 1,427 in 86 posts
Given Likes: 1378
07-21-2021, 05:00 PM
Plz anyone re-upload, thanks in advance
[-] The following 1 user Likes tuanpecc1's post:1 user Likes tuanpecc1's post
  â€¢ hatkam
 tomtumx
User ID: 2851
Threads: 18
Likes: 725 in 124 posts
Given Likes: 772
07-22-2021, 02:33 AM (This post was last modified: 07-28-2021, 10:34 PM by oanm2000.)
[-] The following 14 users Like tomtumx's post:14 users Like tomtumx's post
  â€¢ blaze, zrilek, melekeen, jcbv, daywalker, Dell_Brett, kowheng, PinkPant, tuanpecc1, cace-01, nhim4mat2006, oanm2000, mohamz, cristi
  Excavation Systems Planning, Design, and Safety Joe M. Turner oanm2000 4 3,947 09-27-2012, 09:40 AM
Last Post: shadabg
  Rock Slopes - Design, Excavation, Stabilization (FHWA-TS-89-045) shadabg 0 1,587 08-30-2012, 11:31 AM
Last Post: shadabg
  Design Manual for excavation support using deep mixing technology jacs127 1 2,722 08-19-2011, 06:37 AM
Last Post: hrezaei
