Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Drained Strength of OC Clays
 gianniorlati
Senior Underground Works Engineer
Italy
User ID: 46169
Threads: 64
Likes: 1,673 in 128 posts
Given Likes: 429
09-24-2017, 05:14 AM
Correlation between drained shear strength and plasticity index of undisturbed overconsolidated clays
  • Author(s): K. K. Sorensen - N. Okksel
  • Published By: Proceedings of the 18th International Conference on Soil Mechanics and Geotechnical Engineering, Paris 2013
  • Published Year: 2013
  • Size: 0.715 MB
  • Quality: Original Preprint
  • Abstract: A number of triaxial compression tests have been performed by The Danish Geotechnical Institute over the past decades on undisturbed overconsolidated Danish clays; ranging from clay till of low plasticity to extremely high plasticity marine Tertiary clays.
    The test results confirm that the drained peak angle of shearing resistance can be related to the plasticity index, though a large scatter is generally seen.
    Based on the results and a review of published data a conservative relationship between drained peak angle of shearing resistance and plasticity index for undisturbed overconsolidated clays is proposed.
    The proposed relationship and the interrelation to the effective cohesion are discussed.
[-] The following 10 users Like gianniorlati's post:10 users Like gianniorlati's post
  â€¢ cace-01, zrilek, PinkPant, oanm2000, abualamal, subin91, Evandrojr, Dell_Brett, haiquyppl1984, Trishu999
  Landslides in Sensitive Clays: From Geosciences to Risk Management cace-01 1 1,967 08-26-2014, 06:00 PM
Last Post: r3be1
  LECTURE 3 - DRAINED AND UNDRAINED BEHAVIOUR ANALYSIS vantoancons 2 2,837 12-23-2011, 04:00 AM
Last Post: 3fan
