Civil Engineering Association eBooks Codes, Manual & Handbook ASTM Fracture and Fatigue Control in Structures, Third Edition: Applications of Fracture M
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1405
07-09-2017, 10:20 PM
Fracture and Fatigue Control in Structures, Third Edition: Applications of Fracture Mechanics
Author(s)/Editor(s): John M. Barsom ,Stanley T. Rolfe | Size: 9 MB | Format: PDF | Quality: Original preprint | Publisher: ASTM | Year: 1999 | pages: 532 | ISBN: 0803120826
[Image: 28997486564264864192.jpg]
The field of Fracture Mechanics has become the primary approach to controlling fracture and fatigue failures in structures of all types. This book introduces the field of fracture mechanics from an applications viewpoint. It focuses on fitness for service, or life extension, of existing structures as well as provides case studies to allow the practicing professional engineer or student to see the applications of fracture mechanics directly to various types of structures.
Fracture and Fatigue Control in Structures will serve as an introduction to the field of fracture mechanics to practicing engineers, as well as seniors of beginning graduate students. This field has become increasingly important to the engineering community. In recent years, structural failures and the desire for increased safety and reliability of structures have led to the development of various fracture and fatigue criteria for many types of structures, including bridges, planes, pipelines, ships, buildings, pressure vessels, and nuclear pressure vessels.
Dr. John Barsom is a consultant in the area of fracture mechanics, failure analysis, and accident reconstruction. He retired from USX as Research Fellow and Chief of the Materials Behavior Division.
Dr. Stanley Rolfe is the Albert P. Learned Professor of Engineering at the University of Kansas and has for the past 30 years taught and conducted research on the fracture and fatigue behavior of materials
Table of contents :
Content:
Front Matter
• Preface
• Table of Contents
•Part I. Introduction to Fracture Mechanics 1. Overview of the Problem of Fracture and Fatigue in Structures
2. Stress Analysis for Members with Cracks - Κl
•Part II. Fracture Behavior 3. Resistance Forces - Κc-∫c-δc
4. Effects of Temperature, Loading Rate, and Constraint
5. CVN-ΚId-Κc Correlations
6. Fracture-Mechanics Design
•Part III. Fatigue and Environmental Behavior 7. Introduction to Fatigue
8. Fatigue-Crack Initiation
9. Fatigue-Crack Propagation under Constant and Variable-Amplitude Load Fluctuation
10. Fatigue and Fracture Behavior of Welded Components
11. Klscc and Corrosion Fatigue Crack Initiation and Crack Propagation
•Part IV. Fracture and Fatigue Control 12. Fracture and Fatigue Control
13. Fracture Criteria
14. Fitness for Service
•Part V. Applications of Fracture Mechanics - Case Studies 15. Importance of Fracture Toughness and Proper Fabrication Procedures - The Bryte Bend Bridge
16. Importance of Constraint and Loading - The Ingram Barge
17. Importance of Loading and Inspection - Trans Alaska Pipeline Service Oil Tankers
18. Importance of Proper Analysis, Fracture Toughness, Fabrication, and Loading on Structural Behavior - Failure Analysis of a Lock-and-Dam Sheet Piling
19. Importance of Loading Rate on Structural Performance - Burst Tests of Steel Casings
20. Problems
[-] The following 18 users Like rami1976's post:18 users Like rami1976's post
  • caifan, zrilek, blaze, malc, vvvv, PinkPant, sabooryan, cace-01, febo927, Nita1391, Dell_Brett, sodapas, K.Lee, oanm2000, jcbv, subin91, gulilero, mgdario
  ASTM - Manual on Elastic-Plastic Fracture: Laboratory Test Procedures abudabeeja 1 2,716 11-06-2014, 03:09 AM
Last Post: pram
  ASTM STP1497 - Fatigue and Fracture Testing oanm2000 2 3,279 01-31-2013, 06:29 AM
  ASTM STP1425 - Fretting Fatigue: Advances in Basic Understanding and Applications abudabeeja 0 2,128 10-26-2009, 03:09 AM
Last Post: abudabeeja
